Question about Maytag Neptune MCE8000AY Electric Dryer
Caught fire My dryer caught on fire inside. Is now just doing a code of 1 E5 or E5 with the top of the E missing. Not sure if worth repairing or can repair.
  • 90 Answers
This really is not worth repairing. You may fix one problem but then another will crop up. Any fire,even a small one, will have damaged the wiring. It,s better and safer to buy another one. Hope this helps. Good luck.
Posted on May 20, 2009
Amanda dryer 7200 series error code E5 code?
The E5 error code is only referenced by a technician. More than likely it refers to a circuit board problem. Only solution is to have it replaced by a technician.
Apr 18, 2014 | Amana NED7200TW Electric Dryer
Why do my clothes get caught, burn, and tare in the dryer?
More than likely the front glides and felt have gone bad and wornb away. 1)The first thing you need to do is unplug the dryer.
2) You will need to pop the top of the dryer. This can be done with a flat screwdriver. Place the driver between the top and the front of the dryer and basically just pry upwards.
3)Now, that you can see inside the dryer, the next thing is to remove the front of the machine. At the upper left and right sides you will find a screw that holds the front to the frame of the dryer.Remove these screws and you can take the front off.
4) The glides and felt are located on the inside of the front
May 27, 2012 | Frigidaire Dryers
Turn power on dryer maytag neptune mde9700ayw push start and wont start and shows e5 code.tech sheet is missing from dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 04, 2011 | Dryers
Clothes caught between drum and top of front panel: Frigidaire
You have a bad tub seal. It is glues onto the front panel...looks like a thick felt pad. Common thing on Frigidaire dryers.
May 21, 2010 | Dryers
Maytag neptune has error code e5
What does an e5 error code mean?
Feb 22, 2010 | Maytag Dryers
Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Oct 09, 2008 | Dryers
Fridgidare stackable washer and dryer
Why did it go in the shop anyways?Was it being painted?Ive never removed a dryer to repair it un less it was to be painted.What are you saying about red hot coil?If this is a 220Volt dryer than yes the coils get red hot,thats normal.The repairman is most likely responsible if it caught fire in any way!Sounds un believable to me.
Jan 08, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Clothes getting caught on inside of dryer
There are a couple of guide wheels in the back of the dryer. when they get worn out the tub will have excessive play and will trap clothes inside. Just remove the front cover loosen the belt and remove the drum. the worn wheels will be easy to spot. It is an easy and cheap fix.
Nov 02, 2007 | Kenmore 98702 Stacked Washer/Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
395 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
