Question about ASUS EA-N66 Dual-Band Wireless-N900 Gigabit Ethernet Adapter
3 Suggested Answers
maxcarson
  • 7627 Answers
SOURCE: I have this Wireless Router ASUS RT-N66U Dual-Band Wireless-N900 Gigabit Router, DD-WRT Open Source support, IEEE 802.11a/b/g/n, IEEE 802.3/3u/3ab. What would be a good modem to go with it?
What does your ISP provide? Usually the ISP cable company will set one up that you connect to, or, take a look at these: http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=160&srkey=cable%20modems
Posted on Feb 27, 2013
Geekman
  • 32281 Answers
SOURCE: How to connect the ASUS EA-N66R as a range extender.
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Posted on Mar 09, 2013
Where would I find the key code on my ASUS RT-N66 wireless router?
IF you are trying to set up your router, check your default gateway it should be 192.168.1.1. the default username and password to your router should be admin//admin
Jul 19, 2014 | ASUS Rt-n66u Dual-band Wireless-n900...
Change wi-fi network
Log in to the router page with the username and password and change the SSID of the network. If you dont remember the username and password, then u might need to reset the router but ask ISP settings before you reset the router
Jul 15, 2014 | ASUS EA-N66 Dual-Band Wireless-N900...
Setup wizard
Try doing a hard-reset on the unit. There should be a little inset button on the rear of the unit where you can press it with a pen or paperclip. With the power supplied to the unit, press and hold this button for 10 - 15 seconds until you see the indication/status lights change their pattern. Sometimes all of them will become solid lit, sometimes they will flash, just keep your eye out and look for it. If you dont notice anything, then just make sure you give the button a solid 15 second hold. It can't hurt.
After you do this, try logging into the configuration page and resume setup. Sometimes routers crash. Most all of them are built on the Linux operating system and a crash or glitch is bound to eventually happen. A proper reset usually fixes things like frozen ports, broken wifi or other problems that just seem to appear for whatever reason.
Jan 28, 2014 | ASUS EA-N66 Dual-Band Wireless-N900...
Iphone wont connect to extender
Go into the set up menu of the ASUS. ensure it is not set to 'N only'
Dec 20, 2013 | ASUS EA-N66 Dual-Band Wireless-N900...
Mar 08, 2013 | ASUS EA-N66 Dual-Band Wireless-N900...
Make nat open for rt-n66r
Use portforward dot com. Enter your model and use the instructions.
Jan 26, 2013 | ASUS Rt-n66u Dual-band Wireless-n900...
The gui setup wizard is not popping up/opening and i cannot access www.asusrouter.com
If you're using Windows, plug the ASUS device in via wired (ethernet). Hit Start, then type in CMD, then type in ipconfig. Look for wired local area connection. Do you see 10.0.1.1? That's probably the ASUS. Now, type that in your browser. Voila, the GUI should pop up. It worked for me.
Oct 10, 2012 | ASUS EA-N66 Dual-Band Wireless-N900...
ASUS EA-N66 Dual-Band Wireless-N900 Gigabit Ethernet Adapter Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
