Question about Mitsubishi WD-73642 3D DLP Home Cinema TV
My mitsubushi WD-73642 falshes green timer light rapidly, then it'll turn red?..what could be causing this problem?
2 Suggested Answers
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
Mar 21, 2016 | Mitsubishi Digital Television Mitsubishi...
Why does my status light blink green then turn solid red with no picture
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 14, 2014 | Mitsubishi WD-73642 3D DLP Home Cinema TV
No color on my mitsubishi wd=73642
Check its picture settings. Especially to system settings.
Jan 16, 2014 | Mitsubishi WD-73642 3D DLP Home Cinema TV
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Lamp light is red
pull lamp from unit and investigate it for integrity
Jul 07, 2009 | Mitsubishi WD52527 52" Projection HDTV
Mitsubushi wd 52525 No picture, no sound. Self Dia shows 1.2
No trouble code is 12, is that what your getting? Is red light on all the time or blinking?
Jan 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-73642 3D DLP Home Cinema TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
