Question about Emerson EWF2704 TV
Cant get channels to down load. I have dish cable with the three prong connections.
I accidently changed my tv channel i have dish how do i get my dish back
Meshell Coles,
I would be happy to help get this fixed! If the TV is connected via a Coax cable, try changing it to 3 or 4 if TV1. If it is TV2 try 60 or 73. If the receiver is connected via a RCA (Red, Yellow, White) cable, HDMI cable, or Component (YPbPr), make sure the receiver is on the correct input.
If you have any other questions, just let me know!
Tommy Faust
DISH Social Media Representative
Sep 02, 2012 | DISH Network Televison & Video
I cant connect my dish satalite to my ILO telivision, should it be connected to the ATV port or the DTV port.
If you satellite is HD don't connect it to either port, Use an HDMI or component (5 wire cable) so as to receive high def signals. If you must uase channel 3, You want the ATV input. On channel 3 YOU WILL NOT RECEIVE HD PROGRAMMING> check your hookup guide from Dish network.
Jul 09, 2011 | iLO Televison & Video
What channel does my tv need to be on? and what button do i press on my dish network remote to get me to the wii screen
Usually it depends on how you connected to the TV/satellite box- for instance, I have mine set on channel AUX 1 since I have connected my Wii to the TV using the component cables (the red yellow and white cables) to the port AUX 1. If you've hooked it to the Dish box, then it would be whichever accessory you connected is the channel to select in the dish system, but on the channel that your dish is hooked up (it's situational!)
Jun 25, 2011 | Nintendo Wii Console
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
I have dish network and dont know what channel to go to in order to use my dvd player. I cant find my manual.
Hi my nameis Mike Houston of DISH Network and I was going over your post and see you wantto watch a DVD and not sure what channel or input the TV should be on. Whilewatching a DVD the connectors may be RCA cables (Red, Yellow, White), if those arethe connections you will want to put the TV on either Video1 or Input1. Whilethe DISH Network should be connected to the TV by Coax cable (it will have ascrew on connection). The TV channel should be set to ch3 or ch4, if you haveany questions please e-mail me at michael.houston@dishnetwork.com.
Dec 01, 2010 | Sansui DTV2760 27" TV
TV Stuck on 1 channel
We would be happy to help get that fixed right away. The first thing we want to ensure is that all connected equipment is on. We want to then check what type of cable was used to connect the TV to the receiver. If you are using a Coax Cable to connect the receiver to TV1, check the receiver's back panel for the output name. If your receiver has a "TV CH 3/4 out": Tune TV to channel 3 or channel 4, back if it is labeled "Home Distribution": Tune TV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) to connect receiver to TV1, cycle through the inputs until picture appears; Most TVs have a "TV/Video", "Input", or "Source" button. If we are still not getting a picture then unplug receiver for 10 seconds then plug it back in, this will reset the receiver, then try cycling the inputs again.
We hope these steps resolve the issue. We want to thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 22, 2010 | Emerson EWF2004 20" TV
White screen with dish network
This is an ancient message so you have probably long since found your problem.
There may be additional input settings to be made since it sounds like the set isn't seeing any input. If you are using the cable input on both the receiver and TV, you will have to set the TV to channel 3 or 4 to see the output of the Dish receiver.
There are three common ways to connect; via the familiar cable in/outputs, S-video with a separate audio cable, and possibly DVI. The TV's input may not search for and find the right input since many sets have a setting via their menu to force the set to look at a specific input.
It helps to have both the Dish manual and the set's manual side-by-side.
May 25, 2008 | Akai LCT2060 Television
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Emerson EWF2704 TV Logo
20 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
