Question about GE JGRP17 Gas Single Oven
My GE Xl44 gas burners will not ignite
My GE Xl44 gas stove gas burners will not ignite, there is no spark, but there is gas coming out. It lights up when I put a match next to it. Only one of the burners are working. I tried switching them and they all worked on the one burner for a little while, now none of them work.
  • 5 more comments
  • jilybean Feb 11, 2008
    my mom has the same stove and she has 2 burners that won't ignite, shes tried cleaning them real good but still has to use a lighter to lite them.
  • watch5869 Feb 27, 2008
    Two of the burners will not ignite when cold except by blowing on them. when hot and turned off they will ignite immediately. ?????
  • GEXL44range May 09, 2008
    Same problem. Only the front left burner ignites by itself. Have to  use a match to light the others.
  • vivia727 May 29, 2008
    Same problem. None of my gas burners will ignite. Gas is coming out, and I hear the clicking sound of it trying to ignite, but it doesn't light. The oven appears to be working fine though. I'd love to hear any suggestions.
  • Anonymous Jun 08, 2008
    Same problem. Does anyone know how to fix it?
  • Anonymous Jul 21, 2008
    Same! One out of the four doesn't light w/o a match.
  • Anonymous May 03, 2009
    one of the gas burners on my stove will not ignite, gas comes out but the igniter is not igniting it.
If there is no spark at all then the circut is not being completed. The main problem that I had was that there was no ignition even though there WAS a spark and gas. I cleaned out the small pin hole sized inlet on the gas valve with a needle. This allowed the gas to enter the feeder and distribute the gas towards the ignition spark properly.
Also it is very important that the range be level. If there is a pitch to the range the gas may be exiting the distribution cap improperly resulting in improper distribution!
Posted on Sep 07, 2009
  • 4 Answers
If all of the ignitors spark when you try to light, you may have the drip pans mixed up. sounds crazy, but that was my problem.
Posted on Aug 11, 2012
Same problem. There is ignition, and there is spark, but the flames are really low. Tried to set gas settings, but still no dice. Any help out there?
Posted on Sep 07, 2008
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
Burner Igniter will not Spark
No, actually each knob has its own switch and any knob will energize the spark module which sparks at all burners. So, just replace the defective switch which slides over the shaft of the gas valve. Careful! unplug the unit, these are 120 volt switches. Good luck.
Jan 12, 2010 | GE Ovens
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
My stove does not light. THe brolier and the burners work fine
Hello, This is going to be a problem with your igniter/glow bar. Over time these get old and although you may see it glowing iit still may be bad. Your igniter should glow a brillient yellow and should ignite the gas within 15 seconds of the valve opening.
here is a link showing pictures of typical igniters.
If you have any other questions or concerns please feel free to comment again...Good Luck! Mike
Aug 18, 2009 | GE JGRP17 Gas Single Oven
Ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Feb 26, 2009 | GE JGRP17 Gas Single Oven
XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Nov 27, 2008 | GE Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Gas stove the oven pilot lights but not burner
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
GE JGRP17 Gas Single Oven Logo
3,753 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
