Question about Maytag Neptune MDG5500AW Gas Dryer
Neptune dryer does not produce heat md5500
I have front panel off. i turned on dryer and pushed button saw a quick flash light.no glow .checked continuity is good.what next?
also inside of dryer is full of lent.
thanks mike
    Sergeant:
    Champion:
  • 219 Answers
Did you cheak for dead short by touching one end of the element and one end on the heater housing?if there is continuity then you have a dead short .The lint is normal just clean it out.You may have a bad insultor that the element runs true in the heater housing.Also cheak the wires for dead short very carfully with flash light hope this helped:)
Posted on May 20, 2009
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
My Whirlpool Electric Dryer GEW9250PWO .
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Feb 22, 2015 | Whirlpool Dryers
My Duet Dryer starts runs a minute or two then beeps two or three times and stops. The display lights flash, if I push start it starts again but then stops again after a minute or two. I've gone t
I would first unplug the unit and remove the top cover. There are 3 screws towards the back of it. Push the cover back towards the wall and pull off. To the left you will see a control panel (usually black metal case), remove the 3 screws and flip over so you can see the control. Make sure there are no loose connections. I have ran into quite a few that had relay connection wires loose. If everything is ok. The next thing you would want to do is remove the front lower access panel (kick plat panel) and blower chamber. There is a thermal fuse and a thermistor located behind it. If you have a meter then take the proper continuity tests that are displayed on schematic. Both the thermal fuse and thermistor are fairly cheap. Click Here for a link to a thermal fuse on a Whirlpool Duet Dryerefd097de-8d08-43d9-8d3d-9f8b17924fb9.jpg
Apr 01, 2013 | Whirlpool GEW9200L Electric Dryer
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
Maytag neptune dryer modell md5500. Electirc dryer, contorl panle lights up, heat comes on but drum does not turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 19, 2011 | Maytag Dryers
MAYTAG GAS DRYER MD5500 DOES NOT HEAT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Kenmore Series 70 Dryer will not start at all. No sensation of the start button doing anything when I push it. Thermal fuse continuity is good (0 ohms). Light goes off inside the dryer when I depress...
most likely its the push button that is bad. you can buy one from any appliance dealer that services a kenmore dryer. the part is a reasonable price. you also have to give them the model number and serial number. have a good day!!
Oct 15, 2010 | Kenmore Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
263 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
