Question about Horizon GS1035T Treadmill Walking Belt
Message says LUBE BELT. How do I go about doing this. Having isssues with a sliding sensation while walking. Could this be the problem?
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
The stop button on my livestrong treadmill stopped working and now the lube belt message appeared but i can't reset the message because i can't hold the stop button. What can i do?
First you need to check your walking belt if is not creating to much friction, that's why you have the message, at soon you replace the belt the motor doesn't need to much power to push the belt and the message go away. You can buy the belt on HomeFitnessParts.com
Dec 21, 2013 | Exercise & Fitness
Belt stops at slow speeds
Check the walking belt is tensioned correctly.
Remove power from the mach.
Most machines you should be able to slide your hand under belt, only to about the center of your palm or maybe your thumb.
if walking belt tension is correct. make sure the delt has lube on it. Your owners manual will determine what type (wax or silicone) or manufacturer to use.
When inspecting the deck (laminated board under the walking belt, which it slides on top of), check for wear or damage.
Worn decks and belts should both be replaced at the same time.
Beyond a walking belt area issue, check the drive belt under the motor hood. connecting the drive motor to the front roller. try twisting the belt on its axis. about a 30degree deflection would be standard. If this belt is loose, the front roller is loosing its drive.
Sounds primarily like a belt/deck lube or wear issue.
Jan 05, 2013 | Nordic Track Nordictrack Track C3000...
The belt is stuttering on treadmill when walking on it
1) LUBE the deck belt, this happen to due the lack of maintenance according with your instru.manual follow the step donwloa your instruction manual. go www.fitness.manualsonline.com or www.iconservice.com
2) LUBE the rollers bearing very well.
3) Tight with NOT much tension the drive belt.
4) Adjust the tension deck belt see the diagrams attached.
Sep 02, 2012 | Exercise & Fitness
My machine makes belt gnash noise when i walk on it, like friction sound with the base or platform
1) lube the deck belt very well
2) lube the rollers bearing too
3) lube the bearing from the main motor,+test the pulley+belt for replacement need lubrication go to the repair shop.
4) otherwise you must call some tech for repair.
see the video.
God bless you
Jul 16, 2012 | Proform 380 Treadmill Walking Belt
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
Nov 23, 2010 | Cadence Exercise & Fitness
Treadmill says to lube belt, but we aren't sure where that would be?
Horizon treadmills need a silicon lubricant, placed between the underside of the walking belt and the deck board that it slides across. This should be done about once a year ;o)
Oct 23, 2010 | Horizon Exercise & Fitness
Can walk on it but when i start to run the belt stops and all the electronics go off then come back on
Sounds like the belt and deck needs lubrications. Why I say that when walking you do not drawn as much power as you would running. IF their is a lack of lubrications their is a higher amount of friction thus the Motor Control Board has a internal shut off which prevent further damage to the treadmill. This is a fact that 75% to 85% of the problems are belt and deck related. So i suggest you call Nation Gym Supply @ 1-800-496-7278 order this lube part # TM001 Follow these steps below:
Lift the belt and use approximately ½ of the tube by squeezing the lube in the walking area lengthwise. Move to the opposite side of the treadmill and repeat using the remainder of the lube. Use all of the contents of a single container during application. The lube will spread evenly in the next step. Do not perform this step by hand. The lube is usually not harmful to the skin but has the potential to permanently stain fabric.
Start the treadmill at 2 mph and walk on for about 5 minutes then check centering carefully and adjust as needed following your owner’s manual instructions
May 21, 2010 | Nautilus Sport 5.18 LC Treadmill - Huge...
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
HOW DO I LUBE MY HORIZON T81 TREADMILL
Your lube goes between the walking belt and the deck( the board under the belt). Apply lube as close to the center of the belt as possible then walk at a slow speed to spread lube evenly.
Jul 14, 2009 | Exercise & Fitness
Horizon GS1035T Treadmill Walking Belt Logo
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
