Question about GE Washing Machines
Washer (RESET) I need help reseting the washer so it will wash.. it fells up with water but will not wash can some one pls help..
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
To re-set the electronic control, un-plug the power cord, wait a minute or so and plug it back in, if this doesn't correct the problem you have other problems. Good Luck
Posted on May 21, 2009
I have a LG top loading washer. Cold water will not shut off, making it so washer will not shut off. Water still runs after we unplugged the washer.
Close the cold water valve behind the washer, then try a reset. If that doesnt work, the timer may need to be replaced. Depending on your skill level, you could do it yourself.
To reset the washing machine:
  1. Press POWER to turn the washer off.
  2. Unplug the washer from the power outlet. ...
  3. With the power disabled to the washer, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in, or turn the circuit breaker back on.
Nov 28, 2016 | LG Washing Machines
My roper washer stop during after the rinse cycle. Is their a reset button.
remove plug from wall is master reset. but its most likely a sensor or controller issue? get a service manual first.
Aug 21, 2015 | Roper Washing Machines
Washing machine is not filling with water
mine was humming -a wire had fell off my capacitor plugged it in and it ran good
Feb 15, 2010 | Washing Machines
How do i reset zanussi washing machine ZJD12191?
There is ne reset button in the washer to reset, I suspect that when you tipped the washer over, water has got onto the electronics,, more so since you can here it hissing,could prove to be expensive.
Hope this helps.
Jan 17, 2010 | Washing Machines
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Kenmore elite he3 model # 11044832200 gives me a f15 error code. have already unplugged and replugged every connection between the CCU, MCU and drive motor, machine will fill and drain properly but will...
it because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
LGWM2277H LE light came on does the motor have a reset button i need to push
Hello momof3611
Welcome,
You said, Your LGWM2277H washer LE light flashes. Troubleshooting guide says overload in motor. Is there a reset on the motor that needs reset or does something else need done. washer was working fine until we put a big load of jeans in to wash. when we checked wash soapy water was in washer and I can't get it to rinse. drum is not turning.
If you overload, with to much clothes the weight will trigger this error your having in most washer.
Take some clothes out.
Then try this:
Unplug the washer for 5 minutes, or if you can't reach the plug, turn the breaker off for 5 minutes and then the system should reset itself!
Let me know.I'm looking right now for any reset code in the repair manual too!
Huuum
Please remember to leave a rating.
Oct 07, 2008 | LG WM2277H Front Load Washer
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Washing Machines Logo
154 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
