Question about Hobart Welders 500433 Champion? 10,000 All-in-One 10,000-Watt Generator
My kohler driven hobart champ 10000 runs but only provides power
For two seconds then loses it on weld leads and the same on the ac outlets. Its been raining on it uncovered for two days...could it be a temporary short fixed by drying it out or what could it be? Its a new machine (under one year) and only has 38 hours on it. I got it new.If i turn it off then back on it again gives power for the same about two seconds ( about the time it takes to reach full rpms.) Please help.I used it in the morning and it was fine,but when it started raining again, suddenly this problem occured.I loosened the front panel and blew off the circuit board with my air chuck,but it didn't help. I checked the voltage at the main brushes with it running, and it had power for the same couple of seconds,then dropped to 0 right there at the brushes.
    Problem Solver:
  • 6 Answers
Replace your berrings in the drive its probly as the rpms rise the centrifical force pushes the brushes against the wall causing it to short
Posted on May 21, 2009
Hobart 10000 welder circuit board where to fine one
Any welding supply store should be able to get you one. It comes from Miller.
Jan 13, 2017 | Hobart Welding Tools
What chargers the battery on a Hobart 10000 watt welding machine?
I assume it is a low voltage tap off the welders generator that supplies voltage for welding.
Nov 01, 2016 | Hobart Welding Tools
Hobart welder generator
Sorry we do not have those diagrams.
Oct 31, 2017 | Electrical Supplies
Hobart titan 7000 will not weld
a broken or loose main lead or burnt out armature.
Apr 18, 2012 | Hobart Welding Tools
I have a champion 10000 watt gen welder won't bur
Make sure the switch for remote power or control at machine is on the right setting. It will arc but very faint if this switch is not on the right setting.
Mar 17, 2012 | Hobart Welding Tools
I have a hobart champion 4500, hard to strike an arc. what should i do?
Ensure your engine is in good running condition
The auto idle switch should function correctly
Remove the front cover of the welding generator, held by 2 1/4-20 screws
Behind that cover you will see a brush lock assembly, will have 2 wires connected at the top, one is insulated, one is not, mark the leads before you remove them to maintain correct polarity on the slip rings, the brush block is held in place by two Phillips screws, remove the screws, unplug the brush block,'remove it, check to see if the brushes move easily in the brush block, this is a common problem with these machines, the brushes tend to bind in the block, will not make proper contact against the slip rings.....
Remove the brushes from the holder, using a square of "scotch Brite" wipe the brushes, you may see a line around the brush, remove that by gentle cleaning, install the brush block, connect the leads, install the cover, go to work
Dec 15, 2011 | Hobart Champ 4500 Welder/Generator Outfit...
I have a Kohler 12RES, 12.5kw genset. Less than a
check connections on speedsensor or take down rpms must be a screw or bolt on de fuelpump
Jan 25, 2010 | Kohler 12 kW Emergency Power System -...
Not generating power
The engine is not running the welding transformer. It may be a fuse, drive belt or gear wheel. Or the transformer is shorting out. Check these points in this order if the last one maybe you will have to replace the transformer. The transformer is 2 coils to stop them shorting out where normal electric wire is cover in plastic or rubber the coils are coated with enamel as are sum cooking pans. If this is damaged in any way it will short.
Apr 08, 2009 | Hobart Welders 500433 Champion? 10,000...
Hobart engine drive welder has no power out put
i took an old trickle battery charger,6 volts and energize the armmiture,all so called polarizing,google it ,shows how also
Jan 26, 2009 | Hobart Welding Tools
Hobart Welders 500433 Champion? 10,000 All-in-One 10,000-Watt Generator Logo
520 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
