Question about NordicTrack Exercise & Fitness
My T5zi treadmill won't incline anymore - NordicTrack Exercise & Fitness
bwinton
  • 83 Answers
SOURCE: Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
Posted on Apr 29, 2010
SOURCE: my life fitness f3 treadmill wont incline anymore
I am having the same problem as well!! Can anyone help?
Posted on Aug 22, 2010
ercupa190
  • 12223 Answers
SOURCE: treadmill will incline but not stay up. incline # stays after bed lowers
incline Motor is not working it can be a few different things.
1) may not be any signal from the console which could be a damaged cable(tight the flexible cable from keypanel vs display board)
2) Tight the connector from display board vs lower board ( main motor controller board the console itself has failed.
3) The motor control board may have failed from a worn treadmill belt and deck measure 120VAC input for the board
5) the motor may have burnt out Test try to measure 120VAC.
6) potentiometer geared to the motor adjust it so the console knows what height the incline is at.
7) the gearing can slip, giving the console false information which can cause chassis damage.
Now see the block diagaram that I did , for person like you, for to know how the main motor board has aprox 90% of functions of any treadmills. sincerely. Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Dec 07, 2011
ercupa190
  • 12223 Answers
SOURCE: my healthrider s300i softstrider treadmill
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Posted on Dec 13, 2011
ercupa190
  • 12223 Answers
SOURCE: My treadmill won't start. It sounds like it is inclining when I insert the key but nothing lights and it is not moving.
Dear Sir:
Inside test the fuse and replace use DVOM, or reset the c.breaker
2) Adjust the reed switch see the diagram attached, clean,and tight the connector very well. Tigh the ribbon cable from keypad + connector from display board vs lower board
3) Lube the deck vs deck belt, this produce enough friction.
4) test the input motor voltage,if there are the motor need repair or replace
5) Test the output voltage from the m.motor board for the input motor voltage, if there are NOT the board is faulty.
6) Try after your fix, the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
Posted on May 02, 2012
T5Zi treadmill walking belt motor won't start.
Normally when this happen the controller board motor is faulty.
However you must see the schematic diagram , and the thermo switch inside of motor, if is defective or o.k. YOu must use the DMM, for continuity and test if closed or open.Replace or replace.
Of course you must test the main motor, with Battery 12Volts for for to see if the motor is working or defective.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Testing treadmill motor speed control
Nov 19, 2017 | Nordic Track T5ZI Treadmill Drive Motor...
My HEALTHRIDER H95T treadmill is stuck in the fully elevated (level 12) angle on the platform and will not move
The incline motor is jammed due to a faulty incline sensor or incline motor assy. This is somewhat hazardous if you do not know what you are doing to remove the incline motor. Sometimes you can repair it most of the time you replace the incline motor assy. Must be calibrated upon completion.
Feb 22, 2015 | HEALTHRIDER H95T Treadmill
Incline settings reversed
the wires for the incline motor are reversed on the board.if you follow the wires you should have 2 that look identical. reverse where they connect on the board and see .
Apr 18, 2014 | Nordic Track T5ZI Treadmill Walking Deck
My NordicTrack T5zi Walking Belt Treadmill won't
Very likely your console went out. I usually check for voltage running to the console (the wires in the back) and if it has juice but will not come on, I replace the console. As far as "why", usually it is power fluctuations, it can be as simple as turning on a high-amperage piece of equipment, or running too many electronics on the same circuit. I see consoles go out from low voltage more often than high voltage.
Nordictrack is an Icon product, you can download the product manual and parts diagrams at iconservice.com.
Feb 02, 2013 | Exercise & Fitness
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
    Aug 31, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
    Norda track t5zi when i press go the motor start for about 1 second and then the screen goes dark and then restarts itself. incline works fine. Bought brand new but I have only used this thing a dozen...
    If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
    Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
    May 16, 2011 | Nordic Track NordicTrack Treadmill, A2550
    Exercise & Fitness Logo
    15 people viewed this question
    Top NordicTrack Exercise & Fitness Experts
    Craig Butler
    Craig Butler
    Howard
    Howard
    Ross Metcalfe
    Ross Metcalfe
    Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
