Question about KitchenAid 19.7 Cu. Ft. Side-By-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel
My deli drawer keeps coming off when opened model # KBRA2DERBL what can I do?
3 Suggested Answers
  • 76 Answers
SOURCE: deli drawer freezing food
The temperature in the section or the refrigerator isn't set correctly.
Also, check the thermostats if it is functioning correctly. PLEZE LET ME KNOW.
Posted on Sep 17, 2012
  • 12 Answers
SOURCE: Took our deli drawer to clean. Can't reassemble. Help
If it's the deli drawer from the bottom of you refer and you took the entire assembly out at once you will know because it all came apart when you started cleaning it. If it's got two drawers then you now have a piece of glass a frame with legs on it and two drawers. So open the refer all the way, look at the back and the sides where you removed it from, you'll see some groves or ridges or little nubs take the frame by its self and fit it into those places you see, then take the drawers one at a time ( usually the one closest to the door hinge is best to start) and slide them back into place. take your time because like a dresser drawer there is a notch that you will have to work with that's designed to keep you from pulling it completely out when you open it. then place the glass into the frame on top and your done.
Posted on Oct 02, 2012
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
Will the deli drawer work properly without the glass door/lid? The pin broke off the right side and can't be fixed ... plastic broke off the actual drawer roller on the right. Cheap plastic ... disapp
Call in a repair man, it shouldn't cost that much. Yes, your food will be effected without that plastic door, as the drawer has controls and cold settings just for deli items. You need a special glue for cold. I'd call in a repair man, or order a new drawer replacement from the manufacturer.
Dec 01, 2014 | Maytag Refrigerators
Frigidaire French door model 28 cubic ft - deli drawer freezes cold cuts and cheeses. Model FGHN2866PF1
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
What causes food to freeze in the bottom of the refrigerator & meat & cheese tray
See if there is a temperature setting on the side of the drawer. Mine has a small lever that opens a hole to the freezer to keep that drawer colder. If it's opened too far the food will freeze.
Jul 26, 2014 | Jenn-Air Refrigerators
Oct 02, 2012 | KitchenAid Refrigerators
Deli drawer freezing food
Sep 17, 2012 | KitchenAid Refrigerators
Deli drawer hinge broke
Try searching w/ Google on the brand and model no.
Here's one possibility: Parts
Sep 01, 2012 | Whirlpool GI6FDRXXY
I purchased whirlpool GX5FHTXVA and there is a divider piece of plastic taped to the bottom of deli drawer, I have no idea where it goes. It is not in the manuel.
The wider end of the piece can be hooked anywhere on the back of the deli drawer. Keep the piece bent when you install it or it will scratch the glass on the front of the drawer. Also, make sure the tip of the smaller end is touching the bottom of the drawer before straightening the divider._1165.jpg
Apr 17, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
Deli drawer
Dear Master Tech: The model number is GLRT13TEB3. The problem is every time you try to open the deli drawer it falls straight down.
It is as if the tracks to hold it are too far apart? Also the tracks are part of the glass shelf.
Any help with this annoying problem would be much appreciated.
Thank-you, Nanc T.
Feb 14, 2008 | Refrigerators
KitchenAid 19.7 Cu. Ft. Side-By-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
20 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
