Question about Westinghouse Microwave Ovens
Model wst 3503 manual
Need manual
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
Wst 3501 set clock
read your instr. manual and proceed according download you manual www.retrevo.com
God bless you
Aug 03, 2012 | Westinghouse WST3501 Microwave Oven
I need a manual for a Sharp microwave/convection oven Model R7A85. we purchased a boat with this model - never been used, but have no manual.
The owner's manual for the model microwave oven you have listed can be found at managemylife.com. Just type in your model number under their "Manuals" link and your manual is available .pdf format to be downloaded or printed for FREE. Here is a direct link:
http://www.managemylife.com/mmh/owner_manuals/7040/SHARP-Countertop-Microwave-L0710282?brand_name_search=R-7A85
If you need additional assistance, please post back and let me know. I hope this helps you.
Apr 18, 2011 | Sharp R-7A85 Microwave Oven
I have been given a Sanyo Fan Assisted Oven 1200w / microwave 900w but no instruction manual. Can you help?
We can most likely help you but need and exact model number so we can help you try and find you the correct manual.
I am going to post 2 links that you can use your model number to try and download a manual. In the case of these manuals if you have a model number that is close to your model number it will work for you.
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
You will need your model number.
Also try here:
http://kitchen.manualsonline.com/manuals/mfg/sanyo/emc6786v.html
If you are in the UK you will need to use this link:
http://uk.sanyo.com/support/Instruction-Manuals/
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Microwave Ovens
Need manual for rival's slice crafter model # 1037
Manual for the exact model is not provided by Rival but a manual for similar product is available as a pdf file. Click here to open it.
Model is different but instructions apply to your model also so there is nothing to worry about. For recipes click here to open Rival website.
Note: To open the manual you need the free adobe reader installed onto your system.
If the solution provided is helpful, you can accept it.
Jan 25, 2010 | Rival Microwave Ovens
How to change lightbulbs and how to get bottom off for cleaning
Please unplug your oven before you remove or install bulbs!
The bulbs are often tacked in place with contact cement or hot glue,and sometimes there may have been enough moisture to corrode and seize up.
You could heat them up with a hair dryer to loosen the glue.
That usually works.
You can find helpful exploded view diagrams (and order parts if needed) by entering your full model number here.
These views will help you see how the oven comes apart.
Dec 22, 2008 | Microwave Ovens
I have a Westinghouse WST 3501 Microwave
In this case you need to replace complit asseble door on microwave.
Dec 15, 2008 | Westinghouse WST3501 Microwave Oven
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
Wst 3502
Does it seem like the unit is actually responding in any way when you press another key?
It sounds like a shorted keypad, like the Power key is shorted.
This can be due to wear or moisture, most often from cooking steam or spraying cleaners directly onto the keypad.
You may find it's not economical to repair this, as parts may be unavailable separately.
If you have the manual, you can contact their support line to see.
Nov 04, 2007 | Westinghouse WST3501 Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
