Pace out an area that's long
enough for you to take 10 normal steps, in your natural stride, without
having to turn to one side or the other. Place a piece of tape at one
end of this distance, then stand with your toes flush with the edge of
the tape.
Step 2
Carry another piece of tape
with you as you walk straight ahead, taking 10 steps (5 with your left
foot, 5 with the right). Stop at the end of the tenth step and place the
tape flush with the toes of your leading foot.
Step 3
Measure the distance from one
piece of tape to the other, in inches, with a measuring tape. Divide
this distance by 10 to get your average stride length. If, for example,
you walked 290 inches in 10 strides, your average stride length will be
290 / 10 = 29 inches.
Read more: http://www.livestrong.com/article/93695-set-up-omron-pedometer/#ixzz1uuGDz1tt
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
5 seconds, you will have to start step 3 over again.
7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will
increase continuously. Release when the display shows the Stride Length for you.
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
