Question about Mtd 22" Yard Machine Push Mower
Lawn mower troubles
I need to replace the starter cord on a craftsman 550 mower
model# 10T802 type#1095 code#B1. can anyone please tell me how to do this properly...thanx much
    Sniper:
  • 57 Answers
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
Posted on May 19, 2009
On my 10t802 I simply need horsepower, plug# and air cleaner type or # and oil weight and capacity
take the model # type # and code # to your local mower parts store they will sell you all of that and van tell you the hp.
Oct 05, 2016 | Poulan Garden
Will not idle down once started
Check govner rod Assembly. If it has its springs intact than more than likely the govner is broken inside motor.
Aug 07, 2014 | Briggs & Stratton Garden
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
The lawn mower will start but after about ten seconds it quits. Then it is hard to start up again.
I looked up your engine in the mower parts manual below: (232kb)
http://www.oscar-wilson.com/MANUALS/POULAN/96112008300.PDF
The engine number is: 10T802-1098-B1 vs EA
The ENGINE operators manual is here: (7.66mb & not much help)
http://www.briggsandstratton.com/document/index.aspx?doc=277038WST_J_LO.pdf
The engine parts list is here:
http://www.briggsandstratton.com/engines/shop/parts-and-accessories/illustrated-parts-lists/?modelnumber=10T802-1098-B1
Open the diagram carburetor controls fuel supply and governor spring or use this parts manual link to download the engine parts pdf file: (Best!)
http://www.briggsandstratton.com/document/index.aspx?doc=MS3747_K_LO.pdf
Either the primer bulb item 976 has a pin hole in it or... the diaphragm item 394 has a pin hole in it.
Given the cost of both parts I would replace them both and send you on your merry way if you brought it to me for repair.
There are 2 part numbers for the diaphragm. 795083 (Most models) and 796478 used on type 156 models. The type number is usually on the air shroud near the spark plug.
The primber bulb 694394 is common to both engine types.
As I mentioned earlier one of these items has failed. I recommend you replace them both and your mower will run fine. ( The gas tank and carb have to be removed as an assembly before you can change the carb diaphragm once the tank is removed.
Thanks for choosing FixYa,
Kelly
Jul 29, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
I recently got a green Craftsman with yellow writing "Craftsman" and ("22" Mulcher") I didn't know where to look for the model number. I found a family "YBSXS.1901VC" then "274466" it also said not legal...
You need to take the mower into a SEARS authorized store and have them show you the code meanings. Craftsman has changed a lot of their codes so for the first time this is the only way.
Sep 11, 2010 | Craftsman Garden
Craftsman 550 brand new mower wont start
SONDS LIKE A FULE PROBLEM IT MAY NEED THE CARB CLEAND MAY HAVE BAD GAS
Oct 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a free manual for a Craftsman 15.5 CI,
Go to the sears web site, then go to parts section, then to owners manual section. Type in model and serial number. Then you can download the manual for free.
Apr 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd 22" Yard Machine Push Mower Logo
592 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
