Question about HP PSC 2175 All-In-One InkJet Printer
Can't print in black ink.
HP psc 2175 "all in one", Printer says "press enter to align cartridges" when I press enter it does a little run with the paper. It says "paper mismatch, try changing paper type/size in tray" even though it is the same paper we have always used for this printer. I can not get this to go away. everytime I try to print something, it will only print in color, waisting my color ink. I cant get it to print black even if I mark black and white print in the options.
  • dstarshockey May 21, 2009
    Black ink is new.
  • 68 Answers
Wipe the cartridge of cotton,don't use water.Make sure the black is not empty.
Posted on May 19, 2009
After changing ink carteidge it keep saying align cartridge, what can i do to erase this error?
It is my pleasure to guide you.
These steps will take you through the process of replacement and alignment.
1. Turn on the unit, then open the print-carriage access door by lifting the
handle until the door locks into place. The print carriage moves to the center of the unit.
2. After the carriage stops moving, lift the latch to release the print cartridge, then pull it toward you out of its slot.
3. If you are removing the black print cartridge in order to install the photo print cartridge, store it in the print cartridge protector.
4. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5. Push the new print cartridge into the appropriate slot until it clicks into place. The tri-color print cartridge goes on the left and the black or photo print cartridge goes on the right.
6. Pull the end of the latch toward you, press down until it stops, and then release. Make sure the latch catches below the bottom tabs.
7. Close the print-carriage access door.
align the print cartridges
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge.
Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1. Press Enter on the front panel. A page of patterns is printed. The cartridges are aligned correctly. Recycle or discard the page.
To align the cartridges at any other time:
1. Press Setup.
2. Press 2, then press 2.
This selects Maintenance, and then selects Align Print Cartridges.
I found the manual for this printer, if you do not have it already. If you wish to download it click or copy this link
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 15, 2011 | HP PSC 2175 All-In-One InkJet Printer
My hp psc 2175 all-in-one keeps giving me the message "press enter to align cartridges." When I do that it says" printing align cartrigdes page" then it says "alignment cancelled" and then goes back t
Hello Dear; When you install new cartridge the machine going to alignment it is neccessary you just follow the direction step by step to finished the procedure.
Apr 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
Cartridge alignment
Put a teeny tiny bit of oil (3 in one on fingertip) all over the slide (chrome bar that you see looking into the printer from the front) and retry. Just a thin film, NOT enough to drip.
The self test and align 'scan and print' procedure is timing out.
Mar 27, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP 2175 Printer won't align new ink cartridges.
press 'setup' and 'options' buttons at same time to overide
Mar 19, 2009 | HP PSC 2175 All-In-One InkJet Printer
How to install the print cartridge on the hp psc 2175
I found this site where you can see exactly how to access and change your printer cartriges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu05206&lc=en&dlc=en&cc=us&rule=22474&product=90809
Hope this helps. Bud
Jan 21, 2009 | HP PSC 2175 All-In-One InkJet Printer
Put in a new cartridge
i don't have driver
i want to load driver printer hp psc2210
Apr 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
176 people viewed this question
Seeker5211
Seeker5211
