Question about Bose Wave Radio II
Can I program my Directv remote to work my Bose Wave II? If so what codes can I use.
5 Suggested Answers
Fame_Guru
  • 483 Answers
SOURCE: Bose Wave Radio - Need IR Codes for cable remote
Check this manual,
this will guide you through the setup again :
http://products.bose.com/pdf/customer_service/owners/wrv3_guide.pdf
Posted on Mar 25, 2009
BillB-SA
  • 2761 Answers
SOURCE: The remote for my Bose Wave radio-CD no longer
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Posted on Dec 06, 2009
SOURCE: Would like to connect Bose Acoustic Wave II sustem
If your TV have audio output ( RCA or any kind ) then you can hook that up ( you can buy the cable from radio shack ) then to BOSE audio input w/c is the AUX input.
Posted on Nov 11, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Bose Wave
Remotes only allow you to avoid walking across the room to touch the unit for certain functions - like POWER. They don't actually enable or disable its ability to turn on if power is available. Walk over and touch the power control. If it turns on the remote is still malfunctioning.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Posted on Aug 04, 2011
How to control volume of bose cinemate with directv remote
The code for the Direct TV remote is 31933. It doesn't work with the new RC71 remote (Direct TV limitation with that remote), but it does with the remotes that have AV1 and AV2 options.
Mar 15, 2012 | Bose CineMate GS Series II Speaker System
My 722 wont program to operate my BOSE GS Series II.
russ063
761 47% thumbs_up.gif thumbs_down.gif 780 761 47% thumbs_up.gif thumbs_down.gif 780 761 47% thumbs_up.gif thumbs_down.gif 780
I have provided the codes and instructions on how to program your DISH remote to your Bose receiver. I hope this helps.
Remote codes:761 and 780
Instructions on programming:
Address To Other Equipment Using Code
  • Remotes: Multiple Mode Buttons (TV,VCR, AUX)
    1. Press and hold the desired Mode button until all mode button backlights come on, then release.
    2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Note: The light will blink off after each digit is entered and then return to a steady light.
    3. Press the POUND (#) button.
      If the code entered is valid for the remote, the mode light flashes three times.
Ray Calo
DISH Network
Mar 13, 2011 | Directv (R10) DTV Receiver / 70-Hours...
Remote does not work, battery is good. Can I program my dish network remote? If so what codes can I use.
Sorry to hear about your original remote; we would be happy to help you with addressing your DISH remote to your Bose Wave Radio. Here is a list of some of the codes that we havefor Bose Wave Radio: 761, 664, 656, and 639.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Bose Wave Radio provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Bose Wave Radio. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 21, 2010 | Bose Wave Radio II
Can the new 5 cd changer work with the older Bose
It will work as a manually-operated AUX input, but since there was no remote for the original system so that function won't be available.
Nov 29, 2009 | Bose Wave Music System CD Shelf System
My bose wave radio II remote is not working. I
It will work without the remote, but can ve very unconfortable. If you have a webcam or digital camera or cell phone with camera, then point it to the small lamp in front of the remote and press any button. If the light blinks or keeps on, then the problem may be on the radio receptor. If light is dark, then take it to an electronics store an ask for an INFRARED LED DIODE replacement. This should work well.
Nov 20, 2009 | Bose 35503 Remote Control
What type of battery goes in the remote for a BOSE wave music system
We have a Bose Acoustic Wave Audio System II, and our remote uses nickel metal-hydride batteries CR2032.
Sep 29, 2009 | Bose Wave music system large Remote...
What batteries doe the bose wave music remote needs
We have a Bose Acoustic Wave Audio System II, and our remote uses a nickel-metal hydride battery CR2032.
Aug 31, 2009 | Bose Wave music system large Remote...
Bose remote device code for directv satellite box
im living in st maarten nederlands antillies on the dutchside and i boutgh a sitilite box in newyork i ask the people if that can work in ST.Maarten they said yes but ST.MAARTEN is dish network i cant find the code program for the box that box is direct plus hd dvr directv satilite reciever. please can you help me.
Dec 01, 2008 | Bose 3 2 1 GSX System
Programing Bose Universal remote to DirecTV R15
Check Direct's code info in their info packet.
It should be in there.
Apr 26, 2008 | Bose Cinemate Digital Home Theater System...
Bose Wave Radio II Logo
43 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
