Question about Bush 2871NTX 28" TV
Have not got remote for TV and need to channge to AV channel
    Problem Solver:
  • 4 Answers
Buy a universal remote. Find the code, program it, viola!
Posted on May 19, 2009
No remote need tv in av mode
While ur TV is connected to d AV device which must also be on, run a frequency scan and all available channels including ur AV channel will be detected and saved. After d scan, u can manually change channels to ur AV choice.
Jun 06, 2013 | Televison & Video
I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Regards,
BElectric
Mar 26, 2011 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
I cant find the av button on my tosiba tv. i have got a wee and it wont work any ideas please e/mail me at wchelseablue@blueyonder.co.uk thanks, johnny
there should be an input button somewhere on the remote. if you dont have the remote, some tv models will toggle through the av inputs at the bottom on the channel numbers. try channel down till to ge to zero then hopefully you will see av. if not you will need to go to the remote. if you dont have remote, you will need to go buy a universal remote.
Dec 24, 2010 | Toshiba Televison & Video
Do i need a remote to aquire the av input on the tv
I believe on the Toshiba 14AF44 that you can change inputs by using the channel button on the front of the TV, as well. Either channel down to the lowest channel and then channel down again to start going through the available inputs, or channel up to the highest channel and then channel up again to start going through the available inputs.
Hope this helps!
Feb 18, 2010 | Toshiba 14AF44 14" TV
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
How to select av without remote control
try pressing plus and minus channel on the tv at the same time. works with my daughters tv
Nov 16, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
I lost the original remote to my 27'' television
very sorry for that but you can be changing channel manually on the tv channel buttons, if you sweep on all channels you can go to AV from RF channels, that is before you buy a remote.
try to buy your remote from
www.ebay.com
Apr 28, 2009 | Televison & Video
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Tv will not recognize channels to save, goes to black screen
If you want to get the original remote for this model (AV-30W776), you can find it at this JVC parts ditrubutor:
JVC AV-30W776 Replacement Part Remote Control
Jan 09, 2009 | JVC AV-30W776 30" TV
Televison & Video Logo
215 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
