Question about Emerson DECT 6.0 Expandable Cordless Phone w/ Digital Answering
Phone keeps searching
The word searching keeps flashing on lcd screen.
The menu keeps flashing on and off. I have turn the tv off 4 or 5 times but it still keeps flashing the light on the bottom of tv goes blue then red really fast
How old is your TV? This normally indicates a power problem. It could be any of the following: power supply on the TV, faulty power strip, faulty wall outlet, faulty circuit board inside the TV, faulty power cord/plug, bad airflow/clogged vents restricting air movement into the TV (can cause intermittent power faults),bad sensor inside TV. This is not completely inclusive by any means. It does mean that you should have it looked at. Someone knowledgeable/skilled should be able to determine the cause fairly quickly using a multimeter.
Apr 25, 2017 | Televison & Video
I want to buy the screen(glass) protection and a cover to keep the phone to carry, I want to know where from I can buy these accessories in New Delhi
You can purchase LCD screen protectors on the Internet.
I suggest you Google search for LCD screen proctectors.
Jan 19, 2012 | Cell Phones
What's your problem?nokia 7610 white screen but not fungtions
your mobile is working change your lcd ictry to fullflash the phone with latest firmware
1 check lcd
2 check lcd ic
3 check lcd connector
4 check flash ic or re hot flash ic
1st.change lcd
2nd.display ic
3rd.display connecter
4th.rehot ram
Dec 11, 2011 | Nokia 7610
White screen, can not see anything, when you start mobile, can hear nokia handshaking tune but could see white screen, please help me.
If device shows an white LCD screen displays, you may first check and try to install a new replacement LCD screen. Get a screw driver to unscrew the phone. Remove the LCD screen from the panel. Replace it with a new LCD screen and couple back the phone
But if the problem continues, then try to flash, restore or update the device flash firmware.
But if the phone is under warranty, i will advice you to take it back to the NOKIA store. The phone will be replace or it will be repair for free.
Regards
Jul 06, 2011 | Nokia N70 Cellular Phone
I already replaced my LCD k810i yes it works but the screen is just flashing
Hi, before you Fix the LCD screen was the phone flashing just like that? If yes that means it was not the screen that was the problem after all. it might be from the board of the phone, That is software problem And also might be the LCD screen and software problem..
Software problem are usually caused by application download from the internet or data transfer through the USB cable or bluetooth device. It Can damage a phone....VIRUS..
What you will need to do is too flash the cell phone. Flashing of the phone restores back the lost phone memory back to it's normal state...
To flash the phone, you can use the below link to know more about flashing of phone ans how to flash a phone...
www.hubpages.com/hub/How-to-Flash-your-cell-phone
Hope it helped...
Thanks for using fixya...
Feb 03, 2011 | Sony Ericsson K770i Purple 3G Camera...
Screen problem
The problem is with your LCD. Contact Nokia care centre and change your LCD.
May 12, 2010 | Nokia 5800 XpressMusic Smartphone
Screen keeps flashing
get your LCD replaced, go to a repairer , gonna cost a lil, samething happened to my cell.
Feb 08, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Sony Ericsson K800i, replaced LCD screen but it keeps flashing white
hi! its me kibbs! i think your mobile will be fell down! you want to change the mobile screen in mobile service centre! bcoz of that only your mobile gettin slow! And also service your phone in service shop!
Thank you!
Jun 15, 2008 | Sony Ericsson K800i Cellular Phone
Nokia N72 Screen Shaking
Flashing is the ultimate choice. if this doesnt solve your problem then the problems lies with LCD screen and u will have to replace it
Flashing is ( reinstalling the software) Formatting ur phone and reinstalling the software
Feb 19, 2008 | Nokia N72 Cellular Phone
W850 flashing
Does the flashing screen is it works or not? If it works its the LCD thats making the flashing if it dosent its the software problem. If check that... try charging it.. if its charged its not the software problem..The LCD can be changed from a phone shop or tecnical shop and if you have some skills you can change it yourself but its best to bring it to the shop.
Hope this help!
Dec 04, 2007 | Sony Ericsson W850i Cellular Phone
Emerson DECT 6.0 Expandable Cordless Phone w/ Digital Answering Logo
18 people viewed this question
Top Emerson Lands Phones Experts
Computer Repairing
Computer Repairing
David Burbee
David Burbee
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
