Question about Epson Stylus Pro 7800 InkJet Printer
Maintenance request 0002
My Epson Stylus 7800 have "maintenance request 0002" error message. What is the solution?
Epson
Maintenance request 0002What is this mean?
Posted on Jun 26, 2009
  • 192 Answers
Thhis means you machines needs to be manced by the printers companey.
Posted on May 20, 2009
My Epson 7800 says "no Maintenance tank fitted. Install Maintenance tank.
Look for a sensor or switch that signals the tank is in place. The sensor/switch may be damaged or defective.
Jul 01, 2014 | Epson Stylus Pro 7800 InkJet Printer
How to removed error code 0002 on epson stylus 7800
problem with epson stylus pro 7880
how to removed error code A0000170
Oct 02, 2013 | Epson Stylus Pro 7400/7800/9400/9800 Matte...
Epson Stylus Pro 3800 Maintenance Request 0002 - - What does this mean?
well it can only mean one of a few things.printer head is damage or no good... not worth replacing the brain of the printer is malfunctioning unplug for 10 minutes let sit. Sorry but time for a new printer
Mar 30, 2013 | Epson Stylus Pro 3800 InkJet Printer
What is maintenance code 0002 for epson stylus pro 7800 printer still working, just flashing code, cant find ansure to what the code is. Thanks Jim
Maintenance Code 0002 - Carriage Motor/Ink Tube is near end of life (Clear Carriage
Motor Counter)
If you clear the carriage motor counter it should work until the part expires.
Dec 17, 2010 | Office Equipment & Supplies
Maintenance request 0040 is showing on our Epson stylus pro 7800. Could you please reply with the solution? Thanks.
If you ring epson, they will charge $456.15, i found this forum that may be of help http://www.minilabhelp.com/forum/Blah.pl?v-print/m-1119948275/
one answer posted is this
Please follow the following instructions precisely?.
1) POWER OFF
2) Hold down the ?Paper Source? button + ?Cut Eject? button + 1 paper feed button (Down arrow)
3) POWER ON, whilst holding the buttons.
4) ?View Counters? should appear on the display, so press ?Paper feed? button down until ?Clear Counters? is displayed.
5) Press ?Select type? button + Paper Feed button + wait until ?Cleaner? is displayed.
6) Press ?ENTER? button TWICE
7) Switch machine OFF
8) Switch machine ON
Outcome
The error display should then have disappeared, and should read READY
IMPORTANT
This process can ONLY be followed ONCE before an engineer is required.
Hope this is of help
Oct 27, 2010 | Epson Stylus Pro 7800 InkJet Printer
Hello I hae a problem with my EPSON Stylus Pro 7800 it said maintenace request 0002 what I have to do for solving it
Its more of a fiddly job than a difficult one. Remove both end covers and drop down the tray which has the mainboard on. Loosen the tension on the carriage belt, remembering to check the belt tension on the scale before doing so, then remove the belt from the pinion of the motor. Unplug the connector for the motor from the mainboard, then undo the cable from all the various clips and pieces of tape up towards the motor. Then remove the motor and do it all again in reverse. Once its installed you will need to reset the counter to clear the error message.
Oct 15, 2010 | Epson Stylus Pro 7800 InkJet Printer
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
May 07, 2010 | Epson Stylus Pro 7800 InkJet Printer
Maintenance request 0088 on my epson stylus pro 7880 ,how can i solve the problem
thats your date and time setting, get the adjustment program and do the RTC adjustment
Dec 14, 2009 | Epson Stylus Pro 7800 InkJet Printer
We are getting error code - 00010014
The same has happened to me I replaced one of the inks and got the error message 0010014. I replaced the ink cartridge with another and it began working again or maybe this link might help you.http://www.epson.co.uk/Printers-and-All-In-Ones/Large-Format/Epson-Stylus-Pro-7800/Drivers-Support?target=article&extn=.html&articleId=4286
Good luck!!
Apr 09, 2009 | Epson Stylus Pro 7800 InkJet Printer
Epson Stylus Pro 7800 InkJet Printer Logo
3,669 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
