Question about Jenn-Air JSD2789GEW Side by Side Refrigerator
Water leak @ bottom front left with water turned off
My jennair model #JSD2789AE is leaking, so I turned off the water to the ref and it still leaks @ the bottom left front area
    Problem Solver:
  • 5 Answers
This quite simple, inside the freezer compartment lower half there is a removable inspection cover, or what you may call the rear interior wall. remove this cover/wall and underneath the cooling coils is a drain hole for the defrosted water to escape to the pan located under the refrig. This hole is obviously blocked with some object, possibly just ice. As it is blocked the defrosted ice in the form of water cant exit the normal way so it is over flowing onto the freezer floor. everytime the defost element comes on more water will leak. solution is to clear the drain hose possible with hair dryer , or gently running a firm but flexible plastic tube through the drain tube to push any blockage on through. This has to be done very slowly and carefully.
Posted on May 20, 2009
Whirlpool side by side refrigerator leaking water, model # GS6SHEXNSOO. How do I fix it?
more info needed were water is leaking from door of freezer or fresh food or from bottom of ref. may have cracked filter housing or water dispenser line tell us more
Nov 04, 2016 | Whirlpool Refrigerators
There is a thick sticky black substance leaking from my refrigerator for the past two weeks on the left front side. Frigidaire model p/n 241543966
Hello Melanie;
My name is Peter. I am a retired field service technician.
You do not have a refrigerant leak. Refrigerant is clear in color.
You have a water leak. The black sticky substance is either coming from your bottom condenser cooling coil or just general dirt under your refrigerator that accumulates over time. The coil under your refrigerator collects dirt as well.
You need to pull the refrigerator out so you can get behind it.
Unscrew the bottom back cover. Inspect for the water leak source. Your condensate drain pan may be leaking or dislodged.
The water line to your ice maker may be leaking.
Your water supply shut off valve to your refrigerator may be leaking.
Nov 01, 2014 | Refrigerators
I have a Kenmore Refrigeraor Model No.72132100 and I have noticed water leaking on the upper left shelf. I have tried changing the settings on the refrigerator and freezing setting but no improvements....
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 26, 2011 | Refrigerators
Kenmore side by side ref model #58582891 water line leaking in bottom front of refrigerator, replaced the filter housing, stopped the leak that went into the drip pan. Water drips in front when push the...
Leo Ponder
imufo2
Aug 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
SMALL OUTDOOR BEER REFRIGERATOR DOOR LEFT OPEN OVERNIGHT IT STARTED DEFROSOTNG AND THEN ACTED LIKE IT BULIT UP PRESSURE AND BLEW OUT AIR OR REFRIGERANT AND DOES NOT COOL ANYMORE
Hi, absolutely there's refrigerant (freon) leak check your condenser and evap. for rupture (broken lines) also check for oil, presence of oil means, refrigerant (freon) leak, plug ref, and listen, for hissing sound inside and outside of ref. try to locate leak, or call mechanic, repair leak, change filter drier and recharge, if your evap punctured, you should immediately disconnect ref, and dry all water from evap, prevent water from entering system, could damage compressor, or if water get into compressor, you will have to change compressor oil. yes, you surely have a refrigerant (freon) leak.good luck.
Aug 12, 2009 | Refrigerators
Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Jun 07, 2009 | Maytag Neptune MAH6500A Front Load Washer
Kenmore Trio water leak on front left side
We have the same problem for the second time in 2.5 years.
Six months (Dec 2005) after we bought the refrigerator, water was leaking from the door. Sears repair arrived and informed us it was the water tank leaking. Said it wa a known problem and was replaced at no charge (of course, we were also still under warranty - six (6) months out) --- FAST FORWARD 30 MONTHS (May 2008) --- SAME SYMPTOMS SAME DIAGNOSIS only NOW Sears wants to charge me $155 to fix the problem.
I'm gonna be calling and complaining about that!!!!!
Open your left door and look at the flat face under the bottom shelf (you'll see representative water drops). The water tank is behind this panel.
May 25, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Jenn-Air JSD2789GEW Side by Side Refrigerator Logo
317 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
