Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Francis francis milk steamer not operating
I turn the knob to steam milk and get nothing. It is like the knob is not connected to anything. There is plenty of water in the bucket and it has worked well for several years. The espresso part works fine.
Thanks.
    President:
  • 1,618 Answers
Check the end/nozzle of the steam wand, if you open the wand and while getting nothing it is hot, then the nozzle is blocked use a paperclip to clear the hole at the end of tip. If you have done this already and still no steam then it is clogged where the steam valve connects to the boiler.
Posted on May 20, 2009
2 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: Francis francis milk steamer not operating
Steamer tubes can get plugged up with dried milk and/or calified water deposits in the tube.
With the machine unplugged, turn the tube up to check it, Clean it with a small guage wire.
Soak it in a small cup of vinegar, if needed.
Further cleaning, you can add a bit of vinegar to the water and steam it thru...
Let me know how it goes.
K
Posted on Jun 03, 2009
I have a Francis Francis x1 machine, but when i want to make an espresso shot, and turns on the espresso button, the steamer spour out boiling water (not steam, and not while turned on). Does anyone k
Don't know how your controls are set, but you have two switches on the front and a knob on the right. The switch for the steamer (the right hand switch) should be off. The knob on the right should be turned clockwise to turn in off. Then no water or steam should come out of the steamer wand. If it does, the seal on the knob inside the machine is broken. It can be repaired but only if you're handy with a screwdriver (make sure if you take it apart you disconnect it from the mains).
Jun 24, 2014 | FrancisFrancis! Coffee Makers & Espresso...
I bought a second hand Francis Francis X1 Espresso Coffee Machine & the gauge & Milk frother are no longer working. Any advice?
Perhaps the heating element is broken. Does it heat up at all? If not, the steamer won't work and there will be nothing for the gauge to register.
Feb 02, 2010 | FrancisFrancis! X1 - Stainless Steel...
No steam
You may have a clog in one of the hoses. Otherwise pump may be clogged. Or faulty heater. Is it hot?
Aug 28, 2009 | FrancisFrancis! X1 Espresso Machine
K
Jun 03, 2009 | FrancisFrancis! X1 - Stainless Steel...
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Francis francis x1, blocked steamer
Pour in a solution of 50% distilled white vinegar and 50 % water. Set the steam wand knob to a water setting, and run the solution through there. I would suggest letting a small amount of the vinegar/water solution drip out, then cut the machine off for about 20 minutes - allowing the vinegar to thoroughly soak and decalcify the insides. After 20 minutes, let the remaining vinegar/water pour through.
If the problem persists, Francis Franic is now owned by illy - 1-877-469-4559
-Tha Mp3 doctor
Oct 05, 2008 | FrancisFrancis! X1 Espresso Machine
Francis Francis X 4, milk steam not working !
Is it coming out something at all though the steam nossle? if tis not its probably blockage in the steam pipe, trie and clean it.
if its dripping och just coming out alitle water from the steam nossle i would trie and descale the machine.
Jul 15, 2008 | FrancisFrancis! X4 Espresso Machine
Steam Wand Broken
Something is stuck inside the wand. Get a small pice of wire or small paperclip and inset and try to clear the blockage
Nov 12, 2007 | FrancisFrancis! X3 Espresso Machine
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
511 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
