Motherboards does any1 know of any motherboards with 4 memory slots that will run an amd athlon 5200 and 4gb+ of ram?
  • 1,623 Answers
Hello...there are many that will support 4 gigs of ram, Any AMD2 socket 240 pin board. What form factor board to you want, thats the size? Micro ATX being the smallest up to extended ATX. Do you want a Nvida chipset or AMD based? Some of the boards are AMD 3 ready...meaning you can upgrade the CPU. The case you are installing the board in will be the determining factor for the board size. I will list a few motherboards for you for example.
Asus M3N78 PRO Motherboard
XFX GeForce 8200 Motherboard
Asus M3A78-CM Motherboard
EVGA nForce 730a Motherboard
MSI K9N2 Diamond Motherboard
Gigabyte GA-MA790GP-UD4H Motherboard
Biostar TA790GX XE 128M Motherboard
These are just a few, but will give you a place to start.
If your thinking about future upgrades, the AMD 790 chipset is the ticket...price for performance it can't be beat.
Note: if you are running windows XP it will not reckonise 4gigs of memory...3.3 is the limit. Vista 64 bit will...plus more.
Hope this helps and answers your question.
Posted on May 19, 2009
  • 749 Answers
This board should have everything you want and be ready for a 45nm architecture when you decide to upgrade your processor.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4399367&CatId=2874
Hi, does any one knows about which type of RAM is suitable for the mother board MS-7168 VER 1C for the HP PC and whats the max capacity mine has only got a 512mb and i can see it has four ram slots in the...
Here you go....
CPU Support
  • Socket 939
  • Support AMD Sempron, Athlon 64 and Athlon 64FX processors.
  • Support 800 and 1000Mhz HyperTransport (HT) interface speeds.
System Memory
  • Four 184-pin DDR SDRAM DIMM sockets.
  • Serial Presence Detect
  • Support for single-sided or double-sided DIMMs (DDR 333 / DDR400)
  • Support for up to 4 GB system memory
  • Asynchronous HyperTransport and memory controller interface speeds
  • Supports dynamic link width and frequency change
  • Non-ECC RAM (ECC memory will run in non-ECC mode)
  • Single and dual channel mode operation:
    • Single channel mode with single DIMM, non-symmetrical population or non-identical DIMMs
    • Dual channel mode with 2 or 4 identical DIMMs, populated symmetrically
Sirwriter
Nov 14, 2009 | Computers & Internet
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
Jun 26, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Tech spec
This board came out in October 2003. From the Chaintech tech specs:
  • Socket A for AMD Athlon XP / Duron processors
  • AMD Athlon Processors up to 1.4GHz
  • AMD Athlon XP Processors 1500+ to 3200+
  • AMD Duron Processors up to 1.3GHz
  • Hope this helps & please rate this solution fixya. Thanks.
  • Feb 05, 2009 | Chaintech 7NJS-ZENITH Ultra Motherboard
    Ram Upgrade
    Max speed supported for your mobo is: DDR2-533
    You will have to buy (4) 1gb sticks (2gb sticks not supported)
    To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
    Here is the specs :
    ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
    CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
    Chipset: Nvidia GeForce 6150 LE Chipset
    HD Bus:
    Front Side Bus options:
    Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
    Special notes:
    - Motherboard manufacturer's name: ASUS A8M2N-LA
    - HP/Compaq name: Nodus-GL8E
    NOTE: *Actual available memory may be less w/o 64 bit os
    Dec 24, 2008 | Computers & Internet
    Type of ram
    ASUS A8N-SLI Premium Specifications
    CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
    Chipset: NVIDIA nForce4 SLI
    Front Side Bus: 2000/1600 MT/s
    Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
    Expansion Slots:
    2 x PCI-E x16
    - SLI mode: x8, x8
    - Default (single VGA): x16, x1
    1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
    3 x PCI
    Storage/RAID: nForce4: 4 x SATA 3Gb/s
    NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
    2 x UltraDMA 133/100
    Silicon Image 3114R RAID controller
    4x SATA with RAID0, 1, 10, 5
    Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
    LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
    or see this site:
    http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
    Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
    Hi i have a ram issue
    specs for motherboard mach speed venom
    Memory type ddr2 sdram
    Memory slots 2 X 240 pin slots
    Supported ram 800mhz 533mhz 400mhz 667mhz
    I dont know if this will assist you in sorting problem out
    Aug 02, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
    Trying 2 figure out what type of memory 2 use?
    that looks like an Albatron MoBo but I cant get onto the albatron website to confirm this
    Feature
    AMD Athlon™/Athlon™XP/Duron™Processor
    Socket 462 with FSB 200/266MHz
    2 DDR266/200 Memory Sockets
    6channel AC 97 Audio
    2 ATA133 Channels, up to 4 ATA 133 IDE Devices
    6 USB 2.0/1.1 Ports (4 ports by optional cable)
    Integrated 3D Graphics Engine
    Processor
    Socket 462 AMD Athlon™/Athlon™XP/Duron™Processor
    FSB / Transport
    200/266MHz
    Chipset
    North Bridge: VIA KM266 ( VT8375 )
    South Bridge: VIA VT8235
    I/O Chip : Winbond W83697HF
    Memory
    2 * DDR sockets
    DDR266/DDR200 unbuffered ECC/none-ECC DDR SDRAM up to 2GB
    Expansion Slots
    1 x AGP 4X slot (1.5V Only)
    3 x PCI slots (PCI 2.2 compliant)
    1 x CNR slot (AMR Type)
    IDE / SATA Connectors
    2 ATA133 channels, up to 4 ATA 133 IDE devices
    Onboard I/O Connectors
    1 x Floppy Connector
    2 x USB 2.0/1.1 header (4 ports USB cable optional)
    1 x CD_IN header
    1 x COM (serial) port header (Optional COM cable)
    1 x S/PDIF in/out header (S/PDIF in/out cable optional)
    1 x CPU fan header with fan rotation detection function
    1x System fan headers with fan rotation detection function
    2 x 5 pin system panel header (Intel spec)
    1 x Front audio header (Intel spec)
    1 x IrDA header
    1 x Case Open detection header
    1 x Wake on LAN
    I/O via Back Panel
    PS/2 keyboard/mouse, 2 x USB(2.0/1.1),1xVGA ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
    Power
    20-pin ATX power connector
    BIOS Feature
    2Mb Flash EEPROM
    Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard, Wake on LAN/RTC Timer
    Hardware Monitoring
    2 FAN sensors, CPU/System voltages and temperature monitoring.
    Special Feature
    Certifications
    FCC, CE, BSMI,WHQL
    Form Factor
    Micro-ATX (218mm x 244mm)
    Jul 11, 2008 | Intel Motherboard
    Computers & Internet Logo
    156 people viewed this question
    David Payne
    David Payne
