Question about Hasbro Battleship Live Game
Keeps saying something is wrong with the board
I HAVE A 2004 SWIFT CHOPPER AND MY RIGHT TURN SIGNAL KEEPS BLOWING THE BULBS MINUTES AFTER PUTTING IT IN ANY IDEAS
I think that there is something wrong with the circuit boards or there is something wrong with the fuse. Refer to the chopper manufacture or the dealership.
Jul 29, 2016 | Cars & Trucks
Installed toner cartridge samsung clx6200fx and it keeps saying install toner what is wrong
Did you get a Samsung toner cartridge or an off brand? Toner cartridges have small chips that tell the printer how much toner is left.. Not all of those chips will work correctly.
Mar 28, 2016 | Samsung CLX-6200FX Printer
I just changed heating elements in my edenpure usa 1000 and now it keeps tripping my power strip ?
Check to make sure that the elements are weird in the right place.
See if there is any loose screws or metal on metal.
The elements might be bad
If wired wrong it may not be making a proper circuit.
Check the pcb boards to see if it is touching metal on the bottom side of board.
If you put a screw in the wrong spot it may be grounding something out.
Check all wires for bare spots
Oct 18, 2015 | EDENPURE USA1000 Infrared Heater
Why do you keep saying my password is wrong... I have changed it & it still comes up wrong?
Dorothy, open your email after 24 hours give it one day Then sign in again with a new password and it'll open.
Jan 03, 2015 | Computers & Internet
MY TV KEEPS SHUTTING OFF MISTIBISHI 60
if its shutting off I would say something is wrong, what is model number of set?
Sep 02, 2012 | Mitsubishi Televison & Video
My Fender 212R 100W 2x12 Guitar Combo Amplifier keeps on cutting out. The guy I took it to says there is something wrong with the cylinders? I also could have heard that wrong. I honestly don't know much...
You had best get a second opinion! When somebody says "there is something wrong" means they don't really know the details enough to give you an estimate even. If the amp cuts out sharply I would suspect that: 1. Bad volume control 2. Cracked circuit board 3. Bad solder joint on circuit board 4. Bad jack. These are in order from least to most likely.
Jan 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Tried to start computer it won't boot and keeps beeping
It's telling you something is wrong. The BIOS (Basic Input/Output System) is detecting something is already wrong. Usually, this could be the RAM is bad, there's no Keyboard or Display connected, or *********** board has gone bad.
Check the easiest thing first (connectors to peripherals). Then check the RAM to make sure it's not gone bad.
It's hard to say w/o doing a lot of testing on which component is causing the problem.
Jun 02, 2010 | Jetway K8M8MS Motherboard
Samsung 50'' plasma model ps50b450b1wxxu keeps losing all stored channels and needing re-tuned,tv says weak or no signal, it is only 3 weeks old, is it something i,m doing wrong or is the tv faulty?
If you are always needing to auto program the tuner then I suspect a faulty main board. Bring it back as it should be under a 30 day return policy..
Nov 03, 2009 | Televison & Video
Hasbro Battleship Live Game Logo
42 people viewed this question
Top Hasbro Computers & Internet Experts
David Payne
David Payne
Are you a Hasbro Computer and Internet Expert? Answer questions, earn points and help others
