Question about Canon IPF6100 InkJet Printer
Says close upper cover - Canon IPF6100 InkJet Printer
My printer keeps telling me that I haven't closed the ink cartridges door
The ink catridge door sensor as been damaged.
Clean d sonsor and check sensor connecting wire
Jul 14, 2016 | Office Equipment & Supplies
What does error message 'CLOSE UPPER COVER' indicate?
The printer may be unable to sense that the upper cover is closed when, in fact, it is.
Jan 04, 2016 | Oki Electric Industry MB460...
Error no page in Feeder when there are pages in feeder
Need more information. Does the doc elevator lift the paper to the pick rollers? Check the plastic lever that is attached to the upper feeder cover. Make sure the upper cover is closed properly Verify that the dark colored sensor is clean in the feeding tray
May 05, 2014 | Canon DR-9080C Path-Through Scanner
Close the upper cover
2 switches at the both ends.
Jan 10, 2014 | Canon iPF510 InkJet Printer
Ipf 6100 close upper cover
ipf6100 close upper cover problem help me
Nov 11, 2013 | OKI B4350 Laser Printer
Sharp AR-M550N close the upper left side cover
Close the lower left side cover error :
this problem is for under the left door
for fix this problem push the all part on left side
under the door is important
mehdi ebrahimi iran,karaj
Oct 19, 2012 | Sharp AR-M550N Copier
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
How to replace the upper cutter on the baby lock? which screws to release the old blade?
I also have a babylock eclipse BLE1DX serger & here's how my book says to do it
to replace the upper cutting blade
1.open the front panel
2.remove the screw holding the upper blade
remove the upper blade
3.position the new blade in the blade slot, replace the screw.as you tighten the screw, hold the blade up in it's highest position
4.close blade cover. close front cover
hope this helps you
good luck
Sep 12, 2011 | Baby Lock Eclipse Serger
Im looking for part# of a paper guide that also opens the drum unit shutter cover as you close the duplex unit on the left side of a xerox wc m123
This part you described is sold as part of the Left hand Upper Cover assembly wrinaldo_0.jpg
Also check the black plastic 054K24053 Left Hand Upper Chute assembly, that holds the transfer roller.wrinaldo.jpg
Whit Item, Inc
Oct 27, 2010 | Xerox CopyCentre C123 Black and White...
Replace Panel in Xerox 8550 Color Printer - Close Exit Cover
Open that cover and look in the frame of the machine for an opening. Then look on the upper cover. There is an interlock switch on the machine. The plastic tab on the upper cover often times breaks off and will not actuate the switch, giving you that message.
You can fix it by gluing a paper clip onto the cover. Or call 1-800-835-6100 and order a new cover.
May 14, 2009 | Xerox Phaser 8550DP Printer
Canon IPF6100 InkJet Printer Logo
67 people viewed this question
old marine
old marine
