Question about ASUS P4S8X Motherboard
Windows does not see hitachi 500gb sata on asus p4s8x board
Purchased the above drive (deskstar p7k500) and connected to primary sata connection on the board. i also have 2 ide drives connected. in the bios it shows the sata drive but in windows its not available. i have read on a forum that i need 2 sata drives to create a raid array before they will work. is it possible to use only the 1 sata drive?
many thanks
craig
  • tate2001 May 19, 2009
    XP Professional SP2
  • kd0bga
    kd0bga May 11, 2010
    WHAt VERSION OF WINDOWS ARE U USING?
    Master:
  • 441 Answers
On your desktop, look for the my computer icon(xp) or computer icon (vista) then right click it and then go to manage, then go to storage, you should be able to see your drive there unformatted.
Posted on May 20, 2009
How repeiar my bad sektor hard
You can't really repair it. Replace it under warranty is the best option. If you need data recovery I suggest http://FreeDataRecovery.us
Sep 22, 2012 | IBM HITACHI Deskstar P7K500...
Install hitachi p7k500 full speed
Your motherboard MUST have a SATA 3.0 port. It is usually blue or look closely on the motherboard to see where the 3.0 port is located. If your motherboard doesn't have a 3.0 port your hard drive won't be any faster than a normal hard drive.
Feb 09, 2018 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
How do I slave HDT721050SLA360 500GB 7200rpm
This is a SATA drive, in the SATA configuration each drive is on its own, alone on the cable, no master / slave configuration.
Aug 26, 2011 | Hitachi Deskstar 7K1000B HDT721050SLA360...
My hard disk was being used in an HP machine now it cannot be detected by the machine or any other machine the harddisk is hitachi deskstar model HDP725025GLA380 help me
dear sir,
i think your hard disk is broken.. try to put your hard disk in a refrigerator for one night and then try to connect again to your machine, if you still get the same problem i think you need a new hard disk
May 17, 2011 | IBM HITACHI Deskstar P7K500...
Hitachi Deskstar - Model HDP725050GLA360 Sata 3.0 500 GB S/N RJ3KSXHE Clicking sound after being dropped. Is there any hope of recovering the data on this drive at a reasonable price?
if the hard disk has crashed and the sound when it runs later he failed to be detected by the system, it is difficult to restore the data in it because it was not detected by the computer. The cheapest way is that you replace with only secondhand.
Feb 20, 2011 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
Hitachi Deskstar P7K500 HDD keeps unmounting within Windows....
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Jun 24, 2009 | Computers & Internet
Hitachi Desk star 500GB SATA drive
you can check the jumper, is it on the right place?
besides, some motherboard is indeed do not support hard drive with large size on it...
Jun 08, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
ASUS P4S8X Motherboard Logo
281 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
