Question about Samsung CLP 300 Laser Printer
Vertical lines showing up in printouts both in color and Black and white. All lines appear on the left side of paper portrait view.
I am getting lines on the right side of printouts both in black and white and color. I have new toner cartridges. I suspect the main roller.
Initially I got super frustrated - my warranty is run out, and did all the normal checks, and everything was clean. So after many MANY many hours of searching, i found out how a laser printer actually works (properly), found a service manual, and found out it was the LSU mirror. The mirror actually 'projects' the letter/image to the drum using a negative charge, and since the toner is positive, it grabs onto it!! Voila! That's how a laser printer works. All it took was 5 screws, carefully handling the LSU unit and gently cleaning the mirror (clear glass plate thingy) with a very soft clean tissue. Works like a dream now....if it was under warranty, i would've wasted time dealing with people who act like it's going to take a million years, when it really should take 5 friggen minutes...email me if you have probs leeloominai_de_sebat@hotmail.com and in subject type in 'CLP 315' so it doesn't go to junk.
Posted on Oct 21, 2012
  • 431 Answers
Hi I am Vortash yes this is either a contaminated drum or Roller . it will need to be serviced and cleaned by an engineer .. it could be the heat roller also scorched .. Regards Vortash
Posted on May 19, 2009
Vertical black line at the bottom of my printout
open copier front cover and remove developer unit, after that remove the drum unit ,pullon green handles on each side, the drum unit has a green cleaning lever on it ,make sure it is all the way to right side,
arrows on lever and frame of drum should meet,if this is out of position a line will appear.
Mar 20, 2014 | Kyocera FS-1135MFP
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
Verticle color lines on scanner bed and printout in photo mode
Hardware failure, nothing much can be done, just replace the scanner.
Aug 27, 2009 | Epson Expression 1640XL Graphic Arts...
A Dark Vertical line appears 1 inch into the left side of scan
Most Mustek scanners have a black inside cover on the lid, this can give a black line down the side of the job.
ether cover the inside of the lid with white paper or place a bigger sheet on top of the sheet to be scanned!
Jan 24, 2009 | Mustek A3 USB Flatbed Scanner
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Samsung CLP 300 Laser Printer Logo
653 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
