Question about Sony KDF-50E3000 Television
Replacing fan in sony kdf50e3000
Red light flashes 9 times fan indicator ,how do I get to the fan to replace it
  • 23 Answers
SOURCE: Sony SXRD Projection TV
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identical. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank me...lol...
HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
Posted on Oct 01, 2008
SOURCE: Sony Wide Screen Projection TV KP-51WS520
I had the same problem. blinking 9 times, pausing, 9 times...... remote would not power the tv on. after five minutes of pressing the remote it finally would. after turning it off you would have the same problem. sometimes a half hour of pressing remote in every which what way. finally left the tv on for three days and would mute at nite to go to bed. didn't think that was the best way so turned it off and it never turned back on. checked all the forums and found out it was the g board. unfortunately, you cant buy the whole g board anymore. if you take the back panel off the tv, on the lower left corner is where the g-board is. there are 3 little things to unplug and two screws (phillips head) in the middle of the g board. its simple to figure how to take it out. go to the sony direct parts website. the part # is A1054157A for the g board. since they dont sell it anymore they have a phase 3 program where you send in your old g board and they repair it for 64.95. it'll cost about 8 bucks to ship it to them. better than the 400 bucks the tv guy wanted. address is sony customer satisfaction ctr. , materials door 27H, mount pleasant, PA 15666 there number is 866-748-8272. call first and they give you the step by step instructions what to do. after tax and shipping it came out to less than 80 dollars.even came with a warranty. got it back in a week, popped it in and just love turning the tv on. anyone can do it.
Posted on Feb 06, 2009
welcomejee
  • 10594 Answers
SOURCE: replacing the exhaust fan on a KDS-R60XBR1
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
Posted on Feb 13, 2009
  • 4234 Answers
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Posted on Mar 19, 2009
taran_2005
  • 10515 Answers
SOURCE: Sony kds-60a300
9 blink refers to :-
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive)
Thanks for using "Fixya".
Posted on Jun 24, 2009
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
Sony Wega kp46wt520 no power up, 9 times it blinks red
You will need to replace the G board. You can try replacing the two diodes that usually fail, But because its a complex circuit with the zero cross detection the diode replacement never fixes the issue. Replacing or remanufacturing the G board is the only sure way to fix that issue.
Nov 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV won't turn on. Flashes RED 4 times... shuts off
On this particular set 4 blinks can be either a fan error or a temperature error. Unplug the set and take the back off and see if the fans are running and also check to see if the lamp door might be warped. If the fans are running you probably need a thermal sensor.
Nov 02, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KF-50WE620 - 5 Flashes
5 flashes indicates ballast malfunction. 4 flashes indicates fan not working. I would replace the big fan in the back because it is a common failure for this model. But befor this check to see if the lamp door is warped from overheating. If it is the wiring on the balast good be burnt and the light engine could be damaged.
Feb 02, 2009 | Sony Grand WEGA KF-50WE620 Television
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
10 flashing lights then 9
make sure it is 9 blinking it may be 10
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Red Light Flashing 6 times
A 6 blink usually indicates a bad thermal fuse caused by the lamp temperature getting too hot. I strongly suggest replacing the sirrocco fan that mounts on top of the optical block too. Usually this fan gets clogged up with dust so the lamp temperature gets hotter than it should causing the thermal fuse to open up. Replacing the thermal fuse, sirrocco fan and cleaning the dust from the inside and fans will cure this. A Sony authorized servicer should be able to repair this for you. Good Luck
Jan 05, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-50E3000 Television Logo
122 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
