Question about Sharp LiteOn CD-RW/DVD-ROM Burner
Invalid Disc after finalising
I get 'invalid disc' after the finalisation proceess completed
  • 51 Answers
Clean your lens and change the cd
Posted on May 21, 2009
Initialising and finalising dvd -rw disc
Hi John, several reasons it could be, first off the DVD and Disk has to be compatible and finalise will only work if it was initialize on this DVD recorder. Cheers Greg.
Mar 30, 2015 | Televison & Video
How finalise dvdwriter
When you finalise a CD or DVD disc you cannot add/burn additional data to this disc.
You can finalise the disc by selection this option in the settings before you start the burn process.
May 19, 2011 | Computers & Internet
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
We ejected the cd accidentaly without finalizing from the HHB CDR850. we REALLY need this audio. what can we do?
sounds interesting
did the power fail during recording?
have you tried putting the cd back in the machine?
you should be able to finalise it as long as the PMA completed
the disc wont come out normally untill the PMA rec message finishes.
i have this machine myself.
there is a mode that will scan a disc if the PMA is missing
if power was turned off during recording it usually enters a "REPAIR" mode when turned on again.
this takes 40 mins to complete but the audio can be finalised as normal after it completes.
try putting the disc back in and see if it can be repaired or finalised
darren
Nov 14, 2010 | HHB CDR850 CD Recorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
When I record on DVD +RW disc from my other Tv and try to play it on my combie tv ,it will only play if my disc is finalised. so if I only record 30 mins and have to finalise ,I am wasting the disc. Why...
Some tv's are not capeable of reading Rewritable disks. By finalising the disk you are basically making it a non re-writable and thus allowing your other tv to read it.
Jul 16, 2009 | Televison & Video
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Will not play on computer
Before you can transfer pictures or video from your Canon DC210 to your PC you need to finalise the disc in the camcorder.
You also need to make sure that the DVD drive on your PC is capable of reading a DVD-R, DVD-R DL or DVD-RW format as these are the only disk formats that the DC210 will handle. Not all PC DVD drives can read these formats.
To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then, switch on the camera, put it into playback mode, Press 'Func.', select main menu, select 'disk operations', select 'finalise'. Don't move or shake the camera or switch it off whilst the finalising step is underway - this could cause problems.
Once finalising is complete, put the disk into the PC.
Good Luck.
Mar 25, 2008 | Canon DC210 DVD Camcorder
Cant transfer footage from Canon DC201 onto computer (and eventually internet) Do I need specialist software to take video from DVD to computer?
You don't need specialist software to take video from DVD to computer.
One of two things has gone wrong
1. Your PC cannot read the -R DVD format, or, more likely
2. You have not finalised the disk.
You must finalise the disk in the camcorder before putting it in the PC. To finalise the disk you must have the power adapter connected to the camera, plugged into a wall socket and turned on. Then go to the main menu, select 'disk operations' and you'll see an option to finalise disk. Don't move or shake the camera whilst the finalising step is underway.
Mar 09, 2008 | Canon DC210 DVD Camcorder
Unable to finalise
For some reason one of the discs that i have recorded on will not let me finalise. When i put the disc in it says recording disabled and then i go to the finalise menu and the finalise selection is unhighlighted. How can i fix this so i can finalise the disc and use it on my computer?
thanks
Oct 28, 2007 | Sony DCR-DVD602E DVD Camcorder
Sharp LiteOn CD-RW/DVD-ROM Burner Logo
143 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
