Question about Kenmore Dryers
Kenmore 66712 dryer stops in cycle
Vent pip-e is open all the way up won't restart like it is to hot or something after a few minutes it will start back up
    Scholar:
  • 85 Answers
Your motor bearings are worn out and overheating the motor. It has a overload protector that shuts it down when it overheats. Solution is to replace motor or new dryer. Hope this helps!
Posted on May 20, 2009
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Always on high heat and shuts off after 20 minutes
Check the complete venting system inside the dryer and to the vent outside. Be sure and check for lint & god knows what around the blower wheel. Get everything 100% clean. Insert a thermometer into the vent coming out of the dryer with the vent hose off. Start the dryer on high heat & see if it will go to not over 180% and start going lower like 130% or so if it drops back it's ok . If it don't stop & go down cycle thermostat is most likely bad. The reason it won't start for an hour may be the motor gets too hot. You could put an ohm meter across the connection on the cycle therm and heat it with a small torch or something & see if it will show open after heating. Just a guess lots of things cause these problems. Clean that motor too. Lint may cause it too run hot.
Mar 28, 2014 | Whirlpool Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
I have a Kenmore 80 Series Gas Dryer. We replaced the motor and blower wheel in October of 2010. Recently the the dryer has been stopping while drying clothes. No matter what cycle I put it on, it almost...
Hi, In looking at your problem please do the following. Go behind the dryer. The vent hose that is attached to the back of the dryer has to go straight to the wall outlet. It must not have any bends whatsoever. Its a straight shot to the wall. This should take care of it shutting off and being too hot. You may need, after the above, to change out the cycling thermo. Thanks for your inquiry and hope this helps. Have a Good Day!
Jan 18, 2011 | Dryers
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Kenmore Gas Dryer completely shutting off mid-cycle
sounds like you have a overload switch kicking out or its a thermofuse, or timer something is telling your machine its too hot or a thermofuse or some heat sensor....
Jun 08, 2009 | Kenmore Dryers
Dryer doesn't dry, lint not cloged, gas ignights
When you say lint not clogged I assume you mean the removable lint trap in the dryer. If the drum gets hot (open the door a few minutes into the cycle) then most likely you have a vent problem. You will need to check if the vent is blocked solid either by lint or if the vent pipe is crushed. I would suggest going out to whereever the vent ends on the outside of the building and see if air is getting blown out with the dryer on. If no air is coming out then chances are it is blocked. If the drum is cold then gas flame is not getting hot.
May 12, 2009 | Kenmore 72062 Gas Dryer
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
146 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
