Question about Troy-Bilt Pony Garden Tiller
Starter rope too hard to pull on Yard Machine By MTD
I have already replaced the spark plug and air filter for firing. It takes all my effort to pull this rope. Also primed 3 to 5 x before pulling the rope and still doesn't start?
  • Anonymous Mar 28, 2014
    My dad has got a mountfield manor 5 rotavator and the pull cord has snapped and i was wondering if i could just get a length of strong rope from b&q to replace it could you please advise
  • 41 Answers
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
Posted on May 19, 2009
How do i repair pull string on my yard machine 135202 tiller
remove starter
get new rope
wind spring DONT LET GO UNTIL DONE
feed in new rope , tie knot in rope, replace handle ,tie knot in that end. NOW YOU CAN LET ROPE RETURN IN SLOWLY
May 10, 2014 | Mtd Products Yard Machines 158CC Tiller
Lawn mower won't start
Check spark plug grounded when pulling starter to see if you get fire First. Then , spray(if getting spark at plug) starting fluid in a air intake , if motor fires, you're not getting gas so clean gas tank and carb, then , it should run fine.
May 07, 2014 | Mtd 22" Yard Machine Push Mower
Yard Machine Model 21a-121r900 tiller's pull starter recoil pully slipping
Bend the ears on the flywheel so that they are 90degrees. They are not lining up right.
Feb 16, 2013 | Mtd Garden
Was running and stalled out and wont start again recently got a new spark plug and oil change what could be the problem?
If you have fresh fuel and you know that water didn't get into the fuel or fuel tank, then It sounds like your Ignition Coil (Module) has went bad.
The best way to determine this is to see if you are getting fire from the spark plug. Pull the plug out, and then reattach it to the plug wire. Have a friend pull the starter rope while you hold the plug to the head of the engine. (It may shock you a little bit if the Coil is good.) If you see a blue spark, this is good and your Coil is fine. If you see a white spark, the Coil is not so good and you may want to replace it. If there is NO spark, then it's definitely bad and you need to replace it.
Good Luck!
Jim
Aug 11, 2011 | Mtd 22" Yard Machine Push Mower
2003 yard machine riding lawn mower by mtd model #13ag601h729296-204 is cranking over but not starting can anyone please help
You must first see if the are getting fire at the spark plug. (Make sure you have a god spark plug before beginning this process). Pull the plug out and put the plug wire back on. Have someone hold the plug to the head while you pull the starter rope; or vice-versa, (You may have to get in a dark area in order to see the spark). If you see a blue spark, that is good. If you see a white spark, that is not so good. If you see no spark, that means that the coil is bad.
I can give you further instructions on how to get your machines going, but you must first give this a shot. Then let me know what you find out about each one of them.
Aug 05, 2011 | Mtd Garden
Can't get it to go when I pull the rope
A new plug might help also check HT lead
Jul 26, 2010 | Mtd 22" Yard Machine Push Mower
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
Starter rope broke on yard machine
Take the top off. Remove broken rope. Rewind spring until tight, then unwind one turn. Insert and knot new rope.
Jun 07, 2009 | Mtd 22" Yard Machine Push Mower
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines 22 inch mower, I dumped it on its top over the weekend, bent the blade, replaced it, now wont start, did leak oil out of the air filter, cleaned it out real well still wont start
if you bent the blade most likely you bent the crankshaft too.
Remove the spark plug and pull the rope and remove excess oil from the spark plug hole
check the spark plug for spark if you have none then a flywheel key is sheered a more in depth fix.
If you get it started you may notice a whole lota vibration due to a bent crank shaft or maybe not?
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Troy-Bilt Pony Garden Tiller Logo
748 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
