Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
There is a coin or something stuck under the tumbler and it is LOUD when it spins. I have taken the top and back off and was going to separate the plastic housing on the tumbler and pull it out but cant seem to get the shock absorbers off on the bottom or the spring tension released on top to separate the halves? Any advice short of calling a repair service out? Thanks much, Mike
I had this problem. It was a nail sticking through one of the holes in the drum.
Posted on May 30, 2011
If you dont have screws on your tumbling vanes, you can take a very small screw driver and lightly lift the vain enough for the coins to slide out.
Posted on Feb 11, 2010
Im going to try to help with this one so bear with me im having a hard time under standing this problem there is a gap between the inner and outer tub of about 2" so its hard for me to under stand how spinning the inner tub by hand could make coins on the bottom of the inner tub move now the drain pump runs all the time the unit is spinning and coins can and do get down there and rattle aginst the impeller thats not hard to fix reply for that one next look at the tumbling vanes in the tub see if they screw on if they do then coins could get under there just remove them and check
Posted on Dec 31, 2007
Dec 08, 2012 | Whirlpool Duet WFW94HEX 27" Front-Load...
Sep 16, 2010 | Kenmore HE2 Plus Front Load Washer
Aug 25, 2010 | GE WBSR3140DW Top Load Washer
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Apr 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Mar 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Jul 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oct 12, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Feb 03, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
2,286 people viewed this question
Same problem with my Duet Washer as mcal. I have several coins inside the washer tumbler trapped and they slide down to the lowest level as you hand-spin the drum. Since the drum is tilted, the coins are all in back. Is there an easy way to remove them?
coin stuck under drum
Have coin or screw inside tumbler housing. It beats against the drum when in the spin cycle and sometimes sounds like a jackhammer. Can't get to it. I'm very disappionted with both my Whirlpool Duet washer and dryer. I've only had them a year. Had to replace the electrontic board on the dryer ($300 for the part). Now this.
have a coin stuck in the drum
