Question about Roco Ho 10764 Digital Amplifier Dcc
Roco 10764 MANUAL - Roco Ho 10764 Digital Amplifier Dcc
I have a 500gb roco toshiba external drive. the light is on but it won't read. i tried to change it's cable but still it won't work. how can i fix it?
try and listen to the drive when plugged in, if you hear a faint skipping noise. i suspect it is a fault internally on the reader.
if you have a reciept usually the manufacturer will exchange this. as a repair is very tricky!
Jan 23, 2012 | Toshiba Computers & Internet
DVD967B - I need a manual for the pc board - ROCO-V22A.POWER I NEED TO REPLACE 2 CAPS
please try if this link helps if not post a query with your need:
www.sansui.owner-manuals.com/???SANSUI-manuals.html
Sep 29, 2010 | Sansui VRDVD4005 DVD Player/VCR
Hi I have 500gb Roco Hard disk, in which i hide some folder, which i couldnt able view now even after doing "show hidden file option". Thanks
Use the following command in command prompt and your problem will be gone for sure (it will not delete any content) :-
attrib -r -s -h g:\* /s /d
Note:- (replace "g" letter in the above command by your
500gb Roco Hard disk drive letter)
To open command prompt press WindowKey+R and write cmd in the box and press enter. Then write the above command on the command prompt window and press enter.
Some files are also system hidden and they can only be seen using this command.
---->Attrib command is use to change the Attributes of file/folder to showup(unhide) in windows. use attrib/? at command prompt for help.
Hope this will help....cheers:)
Sep 27, 2010 | Office Equipment & Supplies
Driver for roco web cam
Roco RQ-C071 webcam driver
Apr 02, 2009 | Veo Mobile Connect Webcam
Symbol scanner LS2208
Hello Roco,
you need the Intelli Stand to activate this function. The scanner can recognize it and activates the Hands-free mode himself. Until you reoved it from the IntelliStand again.
Apr 09, 2008 | Symbol LS2208 Handheld
Roco Ho 10764 Digital Amplifier Dcc Logo
184 people viewed this question
Top Roco Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Roco Toy Expert? Answer questions, earn points and help others
