Question about Western Digital Computers & Internet
The usb port on wd5000aads broke can the circuit board be replaced
SOURCE: Segate UBS hard drive with broken USB port
Solution:
i) i would wisely suggest you not to open the compartment of harddisk, try taking it to nearest repair centre since these part are very delicate(like they have delicated soldering ...or components....)
  i would suggest not messup with the broken parts and loose your whole harddisk ..............
Posted on Dec 28, 2008
  • 117 Answers
SOURCE: the port where I plug
Your best bet would be to by a replacement enclosure. Online retailers like newegg.com can sell you one. Find out if your hard disk is SATA or IDE. You can then buy an appropriate external enclosure and move the hard drive inside your WD encloseure into the new one.
Posted on May 06, 2009
  • 192 Answers
SOURCE: I have a SimpleTech 120GB external hard drive.
Simpletechs have a three year warranty so if your drive is newer than that it is covered. You can go to www.simpletech.com (they are really hitachi drives) for details on warranty repair. If you are sure its not covered the case can be opened and inside you will find a SATA drive and you can buy a new SATA external enclosure for 19.99 at Radioshack. This includes the circuit board, cable, and new case.
Posted on Jun 05, 2010
cool78259
  • 228 Answers
SOURCE: my power and usb cable connections broke loose
It can be repaired just use a low heat soldering iron, and use heat sink clips, so that the heat will not
transfer and burn other components. make sure all power cords are removed from the board. use a
wrist ground strap to dissipate any static buildup that can damage components on the board. good luck!
Posted on Aug 05, 2011
gandhiforyou
  • 275 Answers
SOURCE: need a replacement circuit board for a seagate expansion drive
it can be easily fix by computer service center so you please take to the nearest servicing center
Posted on Sep 20, 2012
How do I get data off verbatim 160 gb hard drive that the mini usb port broke off?
Your best bet is to buy a donor drive of the same make/model, remove the circuit board and install it on your broken drive - get your data but don't try to continue to use it after that because it will
fail.
Jan 26, 2016 | Verbatim Computers & Internet
Freecom usb port broken away from circuit board inside enclosure
It is hard to buy replacement for the same enclosure, but there are many USB2.0/3.0 enclosures available on the market for 2.5 and 3.5 inch drives.
Make sure read reviews for issues and performance on those enclosures.
Apr 10, 2014 | Freecom Xs External Usb Hard Drive 2tb
Plastic Pin Divider in USB port broke off
is it on board or not if not just replace it and if not you will have to desolder and get a new one not worth it. get new usb port will go in the back slot of computer then plug it in the usb port on board jim time saver that way.
Jan 16, 2014 | Computers & Internet
How to replace usb port for wd5000aads
wow are you any good at soldering ? no really once something falls
off a printed circuit board it is almost impossible to solder it back
one idea that comes to mind for me that is because I will try before giving up , is to solder some leads to the board that way you'll have allot more room to work and you just might be able to Frankenstein it back to life.
Feb 24, 2013 | Western Digital WD5000AADS 500 GB SATA...
Dear, The USB port on my M-Audio Axiom 61 MIDI controller keyboard has broke inside the board, it fell on the cable and the USB broke inside.. Is it possible to send me a new mainboard replacement...
You should be able to get a replacement part for that. Also depending on how tech savvy you are, might be able to open it up and resolder the USB port back onto the board. No idea of the cost of the part however, depends on the manufacturers part list.
May 03, 2011 | M-Audio Mobile USB MIDI Controller
My daughter broke one of my usb ports in the front of my asus cm1630 how do i get replacment parts can i buy a usb 2 or do i have to buy the whole setup that contains the usb ports and media card slots
USB 2.0 refers to the technology, not the connector itself.
http://en.wikipedia.org/wiki/USB
Obtain another USB connector, and solder it in?
Sure, maybe. Depends on your de-soldering/soldering skills, and if the circuit board is damaged.
> Physically damaged in that the board is cracked, and circuit traces are ripped loose, (Repairable with a jumper wire, or wires), AND/OR the USB port was fried out (Short Circuit), and it fried out the entire circuit board.
Obtain another circuit board? This would be the way to go IMHO, but try to find one.
You may have luck on Ebay looking at Desktop Computers > Computers for Parts, or the actual circuit board itself, dunno.
1) http://www.mouser.com/Search/Refine.aspx?Keyword=USB+female+connector
2) http://www.radioshack.com/product/index.jsp?productId=2062744
3) http://www.mgchemicals.com/downloads/appguide/appguide0805.pdf
(PDF file. Takes approximately 20 seconds to download. {Time it takes also until you see the first page)
For questions post in a Comment.
Regards,
joecoolvette
Dec 12, 2010 | ASUS Computers & Internet
USB CF Card reader broke, how do I fix?
Card readers are cheap.
For example:
http://www.dealextreme.com/details.dx/sku.2708
$5 delivered to your door.
Apr 30, 2010 | Cameras
The port where I plug the cable coming from the computer to the external hard drive broke off the circuit board in the external hard drive. Can I fix it or get a repacement circuit board? Thanks
May 06, 2009 | Western Digital My Book Home Edition 500...
Garmin Nuva 350 GPS
The USB port is soldered to the circuit board, it didn't slide in, it broke due to brute force. I think you have to fork out $170
Apr 14, 2008 | Garmin nuvi 350 GPS Receiver
Computers & Internet Logo
16 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
