Question about Sansui VRDVD4005 DVD Player/VCR
What is cause of incorrect disk error c105
What is cause of incorrect disc error c105
3 Suggested Answers
SOURCE: solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
Posted on May 19, 2009
blkuehn7
  • 5 Answers
Wrong. I have the same model and was playing a movie the day before, put in the same movie and got this disc error. Tried 10 other movies that I have previously played on this machine and same error. It is NOT the disc.
Posted on Mar 05, 2015
When i am loading dvd into player message comes on screen disc format error ?
It's either a non compatible format or the slightest smudge on a disk or disk player will cause an error.....
Feb 27, 2015 | 2006 GMC Yukon Xl Denali
Toshiba DVD player
Does this happen with all discs? What disc are you inserting that gives this error? DVD?
Feb 05, 2008 | Televison & Video
When i try cd it keeps writing error.and reject every cd plates i insert.it was playing normal 2days ago.pls what do i do when error notice appear.the car is honda 2003 model coupe.thanx
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 2003 Honda Accord
I have a Toshiba DVD player SD K741. For the past few days, when I load the dvd, I receive a message on my TV screen "Incorrect Disc." What can I do to correct this?
incorrect disk error are common with the user putting in a disc that is not compatible with the player, in most cases it would have been a RW, that was written incorrectly. If this is not the case and it is a original disc you might want to purchase a cleaning dvd witch goes in and cleans the lens.
If that does not work then the unit's lens might be defective at this point.
1. Try other disc
2. try a cleaning disc
If those do not work then the issue is with the lens.
Thanks for your question please do not forget to leave a rating.
Aug 31, 2010 | Toshiba SD-K740 DVD Player
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Disc read error on my 2005 acura TL gps
Was the door open when you got the message (easy to do)?
Did you close the door properly?
Did you replace the disc shiny side down?
Aug 26, 2009 | 1999 Acura TL
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Incorrect disk error
Here are a few things you can try.
1. Check the DVD's and make sure that it is not scratched.
2. Check to make sure it accepts that brand of dvd disc.
3. Call technician. Number shoud be on the DVD player or on your manual. How long did you have this player? If you have warranty on it, I would return it if # 1 & 2 is not the problem. It could be a mechanism problem.
Good Luck!
Jan 09, 2009 | Disney DVD2100-P DVD Player/VCR
Msdos problem
thats cause you are running the wing 98 of the same hard drive that you are trying to format. What you need to do is create a boot disc. boot from that disc and then format.
you can also boot from a win 98 cd to format as well.. If you have problems doing that let me know and i can walk you through it :)
Jan 07, 2008 | Computers & Internet
Sansui VRDVD4005 DVD Player/VCR Logo
117 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
