Epson Stylus Color 860 InkJet Printer Logo
Posted on May 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turn on, all lights flashing, can't turn off unless i unplug printer
Turn on...all lights flashing....can't turn off unless i unplug printer
  • Anonymous Mar 31, 2014
    Keeps flashing different colors won't turn off unless unplugged
Martin Smallridge
Level 3:
  • Epson Master 419 Answers
  • Posted on May 19, 2009
Martin Smallridge
Epson Master
Level 3:
Answers
419
Questions
0
Helped
289718
Points
1120
It's highly likely that your printer has reached the "service required" point but I couldn't be 100% sure.
I'd recommend downloading the SSC utility from SSCLG, get that installed and then follow the instructions for configuring to your printer model and resetting the protection and overflow counters.
If that works you'll then want to be thinking about cleaning the waste ink pads or installing an external waste kit.
If it doesn't work you have bigger problems and need to describe the flashing patterns and any other symptoms in detail.
Hope that helps.
Martin
Epson cx3600 says not to press ink button unless green on button is on and not flashing but as soon as i turn on it starts to flash
The flashing green light on your Epson Stylus CX3600 printer is indicating an error with the ink system. The error message you mentioned, "not to press the ink button unless the green light is on and not flashing", is likely referring to the ink button that is located on the side of the printer and is used to reset the ink levels.
To resolve the issue with the flashing green light, try the following steps:
  1. Turn off the printer: Turn off the printer and disconnect it from the power source.
  2. Clean the ink cartridges: Remove the ink cartridges from the printer and clean the contacts with a soft, damp cloth. Make sure not to touch the ink nozzles or the copper contacts.
  3. Check for clogs: If the problem persists, check the ink cartridges for clogs and clean the print head.
  4. Reinstall the ink cartridges: Reinstall the ink cartridges into the printer, making sure that they are properly seated.
  5. Turn on the printer: Connect the printer to the power source and turn it on.
  6. Check the green light: Observe the green light and make sure it is no longer flashing
My c5580 printer lights will flash and the printer window will say tune power off and then back on. and when i turn it back on it will not trun on unless i unplug it and plug back in . then after awhile...
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Good Luck!!!!
2helpful
The lights on my hp psc 1410 all in one printer is always on and not goin off. I have manually unpluged it and pluged it back in after a few mins and all the lights appear but no sound is coming from it...
Try a Reset. This is from the HP Web Site:
Unplug the power cord from the unit. Reconnect the power cord into the unit. When the lights begin to flash, press and hold the On/Resume and Paper Size buttons. When only the On/Resume light is flashing, release the buttons. When the On/Resume light is steady, the reset is complete.
Blinking red light, unable to turn off or print
From the looks of your printer. I'd say that one of your ink has a problem. The part where you put the cartridge in, is where your problem lies. YOu'll prob need to get it checked out by an HP dealer.
try changing the ink cartridge and see if that helps.
1helpful
All lights stay on solid, cannot get lights to reset, and printer won't turn off unless unplugged. When plugged back in it goes to the same state. Printer cartridge holder doesn't move to the loading
sir try to put your printer to factory settigs by pressing the "start" & "cancel" button together & while holding these buttons together,try unplugging & replugging the printer power chord 4-5 times from the back panel of the printer....
Lights flash on HP deskjet 6127
from what I read on line at HP forums unplugging the network cable may fix it. Others sat they had to buy a new printer
HP DJ 6127 after change of the cartridge blink lights nothing else happens
All three lights are flashing on my HP Deskjet 6127. I tried unplugging it from the power source and then plugging it back in. When I try to turn it on all three lights flash and it won't turn off with out...
Hi
The HP Deskjet 6127 has four buttons and three lights on the front panel
Flashing lights on the printer indicate the status of the printer
When all the lights are flashing, the printer may need to be restarted
try this 1st press the power button to turn off the printer, and then press the power button to it back on very quickly.
2nd press the power button to turn off the printer and hold it down.
Good luck
Can't print
It flashes orange for a few seconds, and then back to green, and then back to orange every few seconds. I can't shut it off unless I unplug it. It also makes a horrible racket.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
