Question about Black & Decker Garden
Black & Decker electric knife blades do not move
Blades do not move
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
venexcsd
  • 1185 Answers
SOURCE: I need a copy of the owners maual for Black n
Do you use WD40 on the blades between sessions
If you have been cutting resinious branches there is more than a chance that the blades are seized together.
You could try putting the blades into a bucket of very hot soapy water (Without a power line attached or the battery removed )
Leave them to soak for a couple of hours, take them out of the water and give them a try, if they run then dry the blades off with a hair dryer and apply some oil to the surfaces.
If they donT then you have stripped the teeth on the gearbox and you may as well dump them as it will be cheaper to buy a new machine than it is to get B&D to repair it
Posted on Jun 16, 2009
  • 634 Answers
SOURCE: My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Posted on Jul 09, 2009
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
  • 154 Answers
SOURCE: Craftsman 22 in. Electric Hedge Trimmer- blade stopped moving
oil them or loosen bolts and try
Posted on Aug 03, 2009
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
My electric hedge trimmer blades do not move when it is turned on. Suggestions? hs2400 date code 20021249
Check that the bolts or screws holding the two blades together aren't too tight preventing the blades sliding. Lubricate the blades also with WD40.
Jul 14, 2011 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
I have a Black and Decker 17" Hedge Trimmer
id check the electric motor first, was it whining when it was going? like maby the brushes in the motor are worn out. if so u can maby get replacements
Mar 22, 2011 | Black & Decker 17 in Hedge Trimmer
I have borrowed an old Black & Decker electric knife that has 2 blades with it. I don't know how to use it? both blades look the same, but you only have one it at one time don't you?
You use both blades together.. On one blade is a (should be) a small metal knob sticking out from the side. On the other is a matching hole. Hold the blades crossed at 90 deg. Lock the knob into the hole on the other and slide blades parrallel, side by side. Both blades should now slip into the slots in handle and lock into place. They will not be exactly level with each other. One will stick out further.. Plug in power, and push run button.. Blades slide back and forth against each other, just hold sharp side against the meat, and push button.. Cuts like butter..
To remove for cleaning, there should be a small button near where the blades lock in, on the bottom (?) push to release blades.. for washing.
Dec 09, 2010 | Black & Decker Black Decker Slimgrip...
Hi! There is power to the unit....the blades don't move.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Jun 08, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
My Black and Decker hedge trimmer's blades won't move, but smoke and a burning smell comes from the motor. Can it be fixed? How much would it cost?
Your blades are stuck together.
What I did:
And it worked!
May 30, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Black & Decker Blades
the blade jig saw does not stay in on black &decker js2500
Mar 07, 2010 | Black & Decker Scroll Jig Saw Blade
Mower Blades
most lawnmower shops can help you prob just a worn keyway ! or goto black&decker.com for closest repair shop?
Aug 27, 2009 | Electric Lawn Mower
Motor runs, but blades dont move
with engine off, take a screw driver and manually move the blades to make sure that they are not jammed. Then spray the blades down with wd-40 oil and they should move freely again.
Jul 28, 2009 | Garden
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Garden Logo
35 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
