Question about Troy Bilt Tb70ss Gas Trimmer
Easy way to replace weedeater lines
How do you replace weedeater line - it's a style that automatically (as you twist) replaces line as you turn.
Will not stay on
You may need to replace the fuel lines, which allegedly is a common fault. (I don't understand why that fixes them if fuel can get through them, perhaps they weaken and collapse?) Check the fuel path. . The fuel lines are cheap and fairly easy to replace, if that does not cure it it may be a carburettor problem. Also try fresh fuel in it, not stuff that's been stored for a long time.
Jun 22, 2014 | Weedeater Garden
I have a craftsman 32cc weedeater model 316791810. I am not sure how to replace the trim line. Is the line supposed to automatically length itself when the line breaks?
An auto feed line system will do just that and if too much line is released there is usually a cutter inside the edge of the plastic guard covering the string head. I use a Troy Built head on a 32 craftsman and I unscrew the bump knob ...twist and pull out the spring loaded spool....cut a lenth of line 6-8 feet or so....thread the two raw ends thru the two holes in the inner spool....pull them out until they are even with each other....then grasp each one and hold them side by side and wind them onto the spool in a clockwise manner. This is how I do the string head with a split boom that fits the 32cc Sears Power head (an older Troy Bilt).
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
I have a GE side by side refrigerator. The water dispenser has stopped dispensing, but when I remove the water line at the bottom of the door, the water is flowing. The line must be either clogged or...
This is a chronic problem with GE. You might want to talk to them about it. They have been known to replace the door or provide the heater.
Leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
Mar 11, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Trying to replace the line in weedeater Twist/Edgs RTE 115c. I can not get the line to feed into the spool. How is this done?
search youtube "change line on a weed eater" there are several videos there maybe one is similer to yours
Oct 25, 2009 | Electric Garden
I have a 25cc weedeater leaf blower that will not idle. I found that the fuel line broke off at the filter inside the tank. Do I need to replace the line and filter or the tank assembly?
Order a new fuel filter and fit it on the existing line...unless the line is brittle and breaks easy in which case you would replace the line. The fuel lines pass through the tank and are fairly easy to replace plus they ahve the added advantage of being cheaper than a new fuel tank.
Oct 19, 2009 | Garden
Can't get weedeater spool head loose to change the line.
there is three types of heads push, screw, and snap. The screw type have a big ball looking thing on the bottom that when pressed lets the line out. the snap kind are verry distinctive they slid in and two tongs snap in to place you will be able to see them on the out side. the push head just push in and turn.
Jul 23, 2009 | Garden
Replaceing string spool
if its the newer weedeater brand
All you need to do is grab the bump knob end and pull it straight off no turning
wind your line in the direction the arrows on the spool shows you
to put back insert line or lines into the holes and snap back on
be sure the spool is able to move up and down freely after install
May 26, 2009 | Garden
Replace line in poulan electric weedeater model xt110 twist'n plu
Dear FixYa Fan, Friday 2-20-2009 10:44pm EST (USA)
RE: Poulan Lawn Trimmers
Poulan Lawn Trimmer FAQ @
http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html
Dear fitzknight: You will find instructions for putting line on your trimmer at this link http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html#changeline click on the http line preceding but please rate me 1st or come back and rate me before you close this or the Poulan Site!
Thank You,
jackiaria
Feb 21, 2009 | Poulan 12" Electric Twist N Edge Plus...
Troy Bilt Tb70ss Gas Trimmer Logo
881 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
