Question about Sentry Safe Sentry Hmm10 Multi Media Headphone With Microphone
Does it work with ps3 - Sentry Safe Sentry Hmm10 Multi Media Headphone With Microphone
How do i connect my arsenal ps3 controller to my ps3
on the back of the ps3 bluetooth controler there a tiny whole ,put a paper clip to reset controller . when lights are of go to ps3 hold down select and ps3 button at sametime . then horizantily hold the start button. this worked for arsenal ps3 bluetooth controller dont no about original ps3 controller
Aug 01, 2012 | Arsenal Gaming Video Game Consoles & Games
Game does'nt work on ps3 but on another ps3 it works
I believe you have to update your ps3's system firmware.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
Turning on PS3 causes home wireless network to stop working
I have the same problem. My router is located about 1.5 feets from the PS3 and when I turn on the console my wireless network barely works. Something I did was change the frequency of the wireless. It was working in channel 9 and now it's on channel 3 with no problem.
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
Are the PS2 games compatable with the PS3?
you can play ps2 games on the ps3 but only if you have THE 80GB version of the PS3
any other ones EG: 60GB dont work
plz rate
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Ps3?
Check the couplings at either end of the cable. Sometimes these will loosen and can cause a lack of signal strength.
but its probably not the cable, its probably the ps3. HDMI cables don't really break because they are just wires, they don't have moving parts. Try connecting your PS3 to your TV with the regular cable red, white, and yellow connectors that you got when you bough the PS3. If the PS3 doesn't work with the original red, white, and yellow connectors then you know its the PS3. If the PS3 does work fine, you know its either the HDMI cable (still unlikely) or the HDMI connection on your TV or PS3 (more likely
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
PS3 Guitar Hero
Keep in mind that backwards compatibility is not 100% and no that controller will not work with the PS3...
Sure the other games work just fine but you are using a ps3 controller to play them correct??
Yes it is different. The same goes for trying to get a ps2 controller to work on a ps3, it's not gonna happen.
You need to get GH3 with the ps3 controller in order to rock out on the ps3....
Aug 29, 2008 | Sony PlayStation 2 (PS2) Console
Sentry Safe Sentry Hmm10 Multi Media Headphone With Microphone Logo
20 people viewed this question
Top Sentry Safe Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sentry Safe Audio Player and Recorder Expert? Answer questions, earn points and help others
