Question about Harman Kardon Bose® 3-2-1IIBLACK System
Battery wire for amplifier in jdm 300zx 1990
Where can i pass the wire to get from the battery to the amplifier in the trunk? do I have to drill a hole in the firewall or is there an easier way to do it??
    Scholar:
  • 70 Answers
Depending on how large the wire is you could route it to the drivers side and in by the the brake master cylinder. or you could remove the passenger side fender well guard and find the grommet that allows the ecu wires into the compartment. i would not suggest drilling a hole unless you are CERTAIN where it comes out on the other side. bad idea to drill into the ecu....
Posted on Jul 08, 2009
Where is obd2 connection for 1990 nissan 300zx
They are always a foot or less from the steering column. Sometimes under a small cover.
Apr 24, 2014 | JDM Nissan 300ZX 300 ZX 90-96 1990-1996...
Replacing battery cables on 1990 300zx
I have a 1996 300ZX Fairlady Left hand drive. I tried replacing the battery. Now the head light flash and wont start. WHY? must I reset? and Where?
Mar 17, 2013 | 1990 Nissan 300ZX
Were can i drill throught the firewall to run a power wire to my trunk for a amp
i would drill on the driverside, make sure to use rubber insulator around the hole, drill near open area where theres nothing inside, like to the left of steering column.
Aug 27, 2010 | 1990 Geo Prizm
How to run a power cable from my 2000 300m batterie to the trunk for my amp
You normally have to drill a 1/2" hole depending on the size of your wire though the firewall and down the pillar then under the rocker panel by the bottom of the door (where you step in/out) and then on the side of the back seat to the trunk. Expect about 20-30min to run the wire. make sure you use a rubber/plastic gormmet on the firewall to keep the wire from shorting out and you need to fuse this wire off the battery. use the same amp fuse as your amp. (if 60 then use 60 at the battery)
Nov 05, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
1990 300zx non turbo has miss on 2 cylinders
dude, i think you have two spark plug cables cross over. go to your local autozone and find a "firing order" if it was a blown head gasket it would show on the compression test but i'm pretty sure its a spark plug cable cross over.
Jun 23, 2009 | 1990 Nissan 300ZX
300zx lights
What did you wire the neon's to? Obviously whatever you wired it to overloaded the circuit and popped the fuses. Check you fuse box on the inside of the car. You should wire the neon's power directly to the battery. Don't forget the fuse shortly after the battery!
May 11, 2009 | 1990 Nissan 300ZX
Alpine v12 amp no power
its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Feb 12, 2009 | Alpine MRV-T707 Car Audio Amplifier
Firewall openings
ive always used the steering colum, just made a hole or went around the boot. look at the firwall for any rubber boots that have access to the inside and squeeze that wire in there. but if all else fails. you can run the wire under the car to the trunk. making sure to keep away from the pipes and using alot of ties to the frame or other. also you would have to drill hole in bottem of trunk then seal the left over room. write back if you have anymore questions, hope this helps.....
Jan 04, 2009 | 1996 Eagle Vision
Problem with the clutch switch for '90 300zx
check your starter key switch on the steering column.
the contact for the starter is wired to the key selector.
you need the Factory Service Manual fot trace out the wire. In general, the starter wire is red, the current runs from the battery to the key switch then to starter motor.
If you have wired from stater to the battery directly, you are bypassing the key switch.
The clutch switch is mounted on the top side of the transmission near the converter housing. again, you need to located the FSM in order to figure out exactly where it is.
Dec 08, 2008 | 1990 Nissan 300ZX
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
