Optoma ds330 how to connect to ps3 via hdmi - Office Equipment & Supplies
  • 151 Answers
SOURCE: Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
  • 758 Answers
SOURCE: cant connect via hdmi
Put it in standby (Red light) and with the HDMI cable conected, press and keep pressed the on/off button in the console for about 5 seconds.
I hope that helps..
Let me know if that solve it..
Computerrep
Posted on Dec 23, 2008
gymhasafit
  • 31 Answers
SOURCE: cannot connect ps3 to lcd tv via hdmi cable
First off make sure ALL Units using HDMI are Powered OFF! Connect Cable, Then turn on all components. On the PS3 Crossbar (Menu) go to the 2nd column on the left, Then down to Display Settings. Choose Output Settings, Choose HDMI, Use AUTOMATIC. Then do the same with the Audio, HDMI, AUTO Make sure your TV is on the Right HDMI Input! Good Luck!
Posted on Apr 29, 2009
gymhasafit
  • 31 Answers
SOURCE: i want to connect my ps3 via hdmi cable to my
If there is NO HDMI on the TV, There are 2 options to still get HD. 1. Check if your TV has a DVI input, If it does you need a DVI to HDMI converter. This can be a problem with some TV models it might not sync up 100%. 2. I recommend doing this, Purchase the Component Cable For the PS3 from Best Buy or any Game store. Make sure it is the ONE for the PS3!!!!!!!!!!!!!! This cable will give you up to 1080i resolution and stereo Audio. Plug in the Red, Green and Blue into the Component (R,G,B) Input in the TV, The Red and White (audio) will follow into the same Input (White and Red) just match the colors from the cable to the TV. On the PS3 in the Menu go to the 2nd row from the Left and down to DISPLAY SETTINGS. Select Component (under HDMI) check off everything except 1080p and then SAVE by pressing X. If you have a Receiver (AMP) that your Audio goes into, Then you can buy an Optical Cable for Surround Sound. Plug in the Optical cable then on the PS3 go into the menu, 2nd row, Sound Settings, Choose Optical, Then choose Auto and SAVE! Hope this will Help!
Posted on May 04, 2009
SOURCE: can i connect my ps3 via hdmi port to component on my tv
You can get a PS3 adapter cable to hook up to the AVI 4 imput on your Magnavox projection TV (the green, blue and red video and red and whit audio HD imputs) You will have to change the dispay settings to 480p (that is the HD level of the TV). it is a bit tricky because you will have to start in the non HD imput, change the setting (the screen will go blank for 30 seconds) so VERY quicky unplug the yellow, red and white cable from the PS3 and plug in the HD cable. then press the X button or right on the direction pad and the setting should change over. switch to the AVI 4 imput and you should be good to go
TIP: have the HD cable plugged into the TV already to make it quicker so you just have to change the cable in the PS3...a bit of a silly process, but it should work.
TIP2: you can get the cable needed at blockbuster, future shop or best buy.
Posted on Jan 14, 2010
Watch TV (Vizio smart Tv)with my projector (Optoma ML 500)
you cant connect a projector to the hdmi on a tv,you have to connect the cable box to the projector
Jul 03, 2015 | Vizio Razor Led M650vse - 65 Class 64.53...
Sound issues when connected to PS3 with HDMI
I don't think you can hook a PS3 to 350W projector. You are maxing out the PS3 output. Good luck with it
May 03, 2014 | Optoma PRO350W Projector
I am trying to connect ps3. (bought may 2012 with uncharted 3). To my denon 2313 via hdmi. No video at all or sound? Please help
You need to tell the PS3 to use the HDMI cable output. To test have you tried connecting the PS3 directly to the TV. Once you have that working then add in the AVR.
Jan 19, 2013 | Denon AVR-2313CI
The hdmi ports not whork whit my ps3 and my computer port
HDMI sends video from a component to a TV. It most likely will not send video from a PS3 to a Computer. Try connecting your computer to your TV via HDMI, and your PS3 to your TV via HDMI.
Jul 03, 2011 | Televison & Video
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Oct 31, 2009 | Yamaha RX-V363 Receiver
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
No picture connected via HDMI
Your PS3's HDMI settings may be the issue. When you go to turn on your PS3 next time, instead of just pressing the poser button and letting go, hold it for 5-6 seconds until it beeps again and then let go. This will force the PS3 to autodetect your TV again and should bring up the video. good luck!
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
21 people viewed this question
jasbo
jasbo
