Question about Sceptre X32BV-Naga 32 in. LCD TV
I have a 32 inch spectre tv that won't power on sometime unless you unpluge it two or three times. You can't turn it on by remote or the power button on the tv. What is the problem?
2 Suggested Answers
  • 127 Answers
SOURCE: spectre 32inch led ty picture center faded
Check the panel Screen If voltage Is there?
Posted on Nov 04, 2012
I have 32 inch Sinotec LED TV. When I press any button on the control panel "KEY LOCK " appears . How do I deactivate the key lock without a remote control
default would be to unplug for 12 hours or sometimes there is a little pin hole reset hole type button very small that you have to stick a pin or paperclip end into on the front by the power button, hold it in for 5 sconds sometimes this will reset if not get a new remote a universal one.
Mar 07, 2016 | Televison & Video
Emerson tv problems
sounds like a button problem, your remote seems to be in programming mode,
I would take apart and clean,
Take batteries out 1st.
# 2 Take a Q tip with rubbing alcohol and swab your keys.
# 3 use some compressed air to blow out and dry keys.
# 4 Re- set your TV to factory reset.
Power tv up and follow instructions to remote set up.
Jul 18, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Sceptre 32 inch, Blue LED light comes on but no picture or sound.
The internal power supply is failing. You are having to "shock" it into operation by plugging and unplugging.
Jan 01, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
Why won't tv turn on by remote or power button unless we try 4-5 times?
My TV has the same problem.
At first, it was an issue with the button itself, somehow some gunk got down under the button and kept it from pressing down all the way most of the time.
A few days after we fixed that, it started to mess up again, this time it was an issue with the way it transmitted signal to the TV.
If the button being blocked isn't the issue, replace the batteries. If the batteries aren't the issue and you don't have a soldering gun, then you'll need to purchase a new remote.
I bought one from walmart for ten dollars and it works just fine for basic use.
Jan 15, 2013 | Televison & Video
I just bought 32 inch 2 hours ago, and am using it with an antenna. Almost every time I turn to channel 5, the remote freezes and I can't even use the buttons on the side of the tv. I have to...
This is my second set in as much days from Best buy. Exact same problem.
Sep 21, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
TV won't show picture the power and OPC light blink twice together followed by three blinks from the OPC alone.
The main tv Tuner signal board have problems or it is dying or might be dead already.But sometimes this tv will still work and can be used,i have the same tv have the same problems it work for me all the times.By doing this process.Everytimes Power and OPC lights blinks.Just push the remote power switch again for tv to repower the tv power and OPC lights again,have go thought this process pushing power remote switch again have to do this like 3 or 4 times sometimes before the tv to work.Tries websites like Shopjimmy.com or Ebay.com to buy a whole new refurbish main tv Tuner signal board for the replacement.
Jul 30, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
May 06, 2010 | Akai LCT2662 Television
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Vizio LCD 37 Inch Turns Off Randomly
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
Jan 15, 2008 | Televison & Video
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
Sceptre X32BV-Naga 32 in. LCD TV Logo
18 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
