Question about Mitsubishi WD-Y577 Television
The TV turns off randomnly after about 20 minutes.
The lamp has just been replaced and you can turn the TV off and right back on. The cycle just continues. Can you help us?
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
  • 395 Answers
SOURCE: DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Posted on Feb 21, 2008
  • 64 Answers
SOURCE: Mitsubishi TV #WS 5531 hd 1080 upgradable - Screen
Most likely burned out lamp.
Posted on Aug 11, 2009
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Posted on Oct 31, 2009
Testimonial: "no wonder you are an expert, we are nothing without you. huge thanks"
SOURCE: I have Mitsubishi WD-Y57 DLP.
I have the same TV. Mine is almost 3 years old. From what I've learned you should try to reset the TV. There is a small button in the front input compartment. Use a pen to push that in and wait for the green light to stop blinking. Then try the TV.
If that does not work you probably need a new lamp. Apparently the lamps only last for a couple years on average. Having to replace them can really add to the cost of buying/owning one of these TV's
Posted on Dec 01, 2009
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
I have a Samsung PN50C490B3DXZA and it turns off and on by itself in about three minute cycles. Any Suggestions?
t looks like you have checked the switch for the lamp cover, which would be my first guess.. Also try removing the lamp and re-placing back into the TV. May be a faulty connection.
To be honest with you, to me it seems like it's a faulty lamp... I've had a similar problem on a TV where when the TV is cold it would turn off, but after turing it back on every 5 minutes, it would warm up and start to move again... The problem was a faulty bulb... But the owner had switched it on and off so many times back to back that the ballast had to be replaced as well!
If not, it would be a faulty ballast. Those are the only two things that could be wrong with your TV in my mind. Your cheapest and fastest diagnosis is to buy a replacment lamp... even if it isn't the problem, you will not lose because you will need a backup lamp in the life of your TV!
Make sure you buy an original philips bulb. I think www.discount-merchant.com is a great reputable source. For $129, you can't lose. I call on these guys all the time. They will ship to you the same day and you will be able to diagnose further in less than a week. If it is the problem, you can call samsung and claim your lamp under warranty and they will replace the faulty one with a new one (but it will take 8 more weeks).. The new one could be your new replacement!
I don't recommend getting an aftermarket/OSRAM/LTI lamp... You may experience the same problems.
Hope all this writing was helpful!
Jan 13, 2012 | Samsung Televison & Video
Powers off with a blinking standby light for 45 blinks
Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light.
Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 25, 2010 | Sony KDFE50A10 50" HDTV
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
TV turns off while watching it then turns back on after abt 1 min
TV needs new lamp as symptom shows existing lamp is weak and causing repeatedly on-off
Please replace lamp in TV, replacement procedure is written in user manual and it is not difficult.
Always buy Sony original lamp for TV safety.
Let me know if you need further help.
Thanks.
Sep 22, 2009 | Sony Televison & Video
Sony 46" rear projection LCD HD - picture and sound go on and off
personally i would call a tv repairman out to fix the set.you can get alot of different opinions on here about what it may or may not be but the best thing to do is call a repaiman and let them fix it
Jan 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony full definition lcd model 1080
Yes you have a bad lamp. Unfortunately, I have noted that many dealers either "forget" to tell the customer that the lamp will require replacement, or they overstate the expected life of the lamp. The usual life of a lamp, as stated by Sony is 4000 to 8000 hours. There are 3 factors that effect lamp life:
1) the number of times the TV is turned on and off. Every turn on works the lamp very hard, so to make the lamp last longer, limit the number of turn on/turn off cycles. My rule of thumb is this: If you will be back to the TV within 30 minutes, leave it on.
2) Proper ventilation. In general the TV should have at least 6 inches of space on all sides to properly cool.
3) Power loss. If you have frequent power outages, buy a small UPS for the TV. The TV requires a "cool-down" cycle where the fans run to properly cool the set. If the cooling cycle is interrupted, it can effect lamp life.
Replace the lamp with and original Sony lamp and vacuum any openings you can see that are dusty and you should be good to go. Be sure to rate this solution. Thanks!
Oct 30, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
XL-2100U lamp cycles on and off
Hi
I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
Sep 10, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Mitsubishi WD-Y577 Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
