Home | Toshiba | DP5570 Laser Printer | Copier makes faded cop...
Toshiba DP5570 Laser Printer
Problem for Toshiba DP5570 Laser Printer
Copier makes faded copies, even though it has toner
By ajamessloan on May 19, 2009
A Toshiba DP5570 copier is producing copies that are faded, as if the copier is low on toner, even though the copier has plenty of toner. What can I as the end user do to solve the problem?
Best Solution
posted on May 19, 2009
Helpful)
frcs68
Rank: Wiz
Rating: 82%, 985 votes
the heater unit is the problem.
yo can get a repair kit by search on the Internet or go to Toshiba web site.
the repair kit come with instruction, if you can handle the mechanic part of things. then you are all set.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 07, 2009
Not Rated)
olindo163
Rank: Master
Rating: 75%, 1 votes
also your looking at a new developer and a new drum those can cost a fade copy and a low toner so check for those thing first when was the last time you change the toner and the drum and developer good luck
Was this helpful?
Yes
No
Popular Solutions for Toshiba DP5570 Laser Printer
Questions and Unsolved Problems for Toshiba DP5570 Laser Printer
Do you recommend Toshiba DP5570 Laser Printer?
Answer
Answer
have a dell 944 AIO and am trying to install it to my new computer tower. says it is installed but... (More)
Answer
We have a Acoustic Solutions DVD model DS 5711D, it loads dvds put it does not play. We need an... (More)
Answer
A sign ''remove paper form dulexer'' pops up and won't allow me to make double sided copies.
Answer
I am trying to print on legal paper and it will not let me. Please help
Answer
our papaer jammed then we got a prompt saying set developer unit
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba DP5570 Laser Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
