Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Belkin G+ wireless receiver
Hello
im having great difficulty finding answers via the web to this problem - which is - i have a netgear router (with a wireless arial on it) and i have purchased a belkin G+ receiver for it under the good advice of the staff at the shop , the thing is when i follow the instructions to set it up it doesnt recognise any connection , i only have the one PC and i want to use that PC in another room away from the telephone outlet where my router sits ,but do i have to delete the connection thats set up allready and heve it unpluged from my router to then make a connection wirelessly ???
  • 1 more comment
  • kobikai Oct 19, 2007
    thanks patters ,i buy you a beer
  • smudge4137 Feb 04, 2009
    i ha
    i have a belkin f50d7050wireless adapter g with a netgear wirelss router load disc loads ok when i open it it says cant reconise it tried on a different computer with same results
  • 70 Answers
You will need to set up the router first, with a wired connection.  Write down the wireless settings for setup later.  Then setup the wireless receiver on the PC with the same settings that you had on the router.  You should remember that distance, obstacles, etc. will affect a signal.  Also, remember that you may not be the only one in your area with a wireless network, so remember to change the channel on the router to something other than the default, and set up security, at least WEP.
Posted on Oct 19, 2007
SOURCE:
Getting error message Belkin/router application has stopped working ( I cant get it to connect..and Im not picking up any wireless signals at all from my laptop )
Try resetting the Router to the factory default settings.
Update your Router firmwire
http://en-us-support.belkin.com/
I have had the similar kind of issue and was not aware what to do. While searching the web, I got the info about TheBestPcDoctor and I contacted their support. My issue is fixed and the computer is running fine now. If you need you may also contact them @
www.thebestpcdoctor.com or via 877-407-9229
Please Rate if you find it useful
Aug 23, 2011 | Belkin Surf N300 Wireless N Router
When im installing the belkin n300, im about halfway done and then it says "the disc is damaged" even though there isnt a single scratch on it?
You can goto the Belkin website and download your drivers
Dec 14, 2010 | Belkin Surf N300 Wireless N Router
CHANGE FROM WIRELESS TO WIRED INTERNET CONNECTION
It is possible .. just get youself an ethernet cable .. connect one end to your router and the other end to the back of the pc ( ethernet port ) .. and u will be connected via the wire.. You can disable the wireless connection from the router for that you can either call your Internet service provider or the netgear support team.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 24, 2010 | Computers & Internet
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
I purchased a Belkin N1 Wireless USB adapter recommended to me by PC World but it is not working correctly. It WILL locate my network but will NOT allow internet access on it. I did ask specifically in the...
Hi there!
Theoretically, it should work with each other. I didn't find any documentation at Belkin's site that states the N1 USB adapter being not compatible with 3rd party devices like your Netgear router.
From what I know is N-Draft's wireless technology should be backwards compatible with both wireless-B and wireless-G devices.
1. Do you have other working wireless devices at your network during that time that you have the N1 USB adapter?
2. Were you able to connect to your wireless network? If Yes, what was your IP address at the wireless computer incase you had the chance to check it?
Maybe you can try to inquire with Belkin about what you've encountered with their device for clarification.
Hope this helps!
May 04, 2008 | Computers & Internet
Security problems
You are looking for the WEP key that is configured on your router. Use your PC that's connected via ethernet, go to the config web page for the router and somewhere on the wireless security settings you will find the WEP key that was configured for your wireless network.
Nov 18, 2007 | NetGear WGR614 Wireless Router
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
