Question about NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS)
Signal strength all wireless equipment, laptops, ipads, cell phones all go slow and get weak signals.
    Problem Solver:
  • 8 Answers
Check with your service provider. You may be in a fringe area or receiving a poor signal because of interference. If your router has the option to add an external antenna that may solve your problem.
Posted on Jun 08, 2014
tom19511
  • 1601 Answers
SOURCE: cant connect
Roger Dodger.. Make sure that your security1.gif password is correct.
Then:
start>control panel>administrative tools>services
Make sure your DHCP client and wireless zero client are started and set to startup type automatic.
Posted on Jan 14, 2008
beeveez
  • 167 Answers
SOURCE: my netgear Wireless-G usb 2.0 adapter wg111
Try to change wireless network name of your router.
Posted on Mar 09, 2009
anandg27
  • 1272 Answers
SOURCE: I'm trying to get an internet connection on my
Hi, Follow the steps below to configure the below settings:
1. Double click on MA111 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
2. Click on networks tab.
3. Click on the SCAN button - This will show a listing of all available networks.
4. Select the network you wish to connect to and click on the "CONNECT" button.
5. This will automatically take you back to the settings tab.
6. If you are using WEP security then Enter the WEP KEY under the option 'Enter Key manually' under the settings Tab.
7. Apply Settings .
8. This should get you connected to your selected network.
9. Click on the 'About' tab and check the IP address.
10. If you are getting an IP address in the format of 192.168.x.x, try to go online.
11. If you are not getting an IP or the IP is in the format of 169.254.x.x, restart the computer and then try to go online.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 30, 2009
SOURCE: signal comes and goes ,internet explorer cannot open anything
if it conencts but gets disconnected as mentioned it turns red possible that something is interfering with the network signal from your system to the router...... try checking for applications programs that can casue your wireless to fail from conneting, check if you have network magic on the computer uninstall it it can cuase network conflict and failures to conenct wirelessly or if your laptop is a Lenovo and if it has readycom 4.0 or readycom 5.0 uninstall it as well.
Also have you tried reinstalling the drivers for your wireless card in the laptop possible that the drivers installed is incorrect or corrupt, you can download drivers for your systme possbily from your OEM Original Equipment Manufacturer ^_^
Posted on Jun 04, 2010
  • 125 Answers
SOURCE: Incredibly slow speeds with netgear
Try updating the firmware for your router or upgrading the router itself if it's old.
Posted on Apr 05, 2011
LENOVO G780 WiFi problems
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 02, 2013 | Lenovo G780 2182 laptop
Lose nettalk connection from router after on phone for twenty minutes
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 28, 2013 | netTALK DUO Wi-Fi VOIP Internet Phone...
Sony vaio loses wifi handshake
Jan 24, 2013 | Sony Computers & Internet
Why does my wireless internet keep turning off
Sep 26, 2012 | Compaq Presario CQ60-220US PC Laptop
I have a acer laptop the keeps turning off wirless connection
Aug 20, 2012 | Computers & Internet
Internet keeps cutting off on my new laptop
If you are using a wireless connection then -
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Mar 17, 2012 | Computers & Internet
Wireless problem
LOSING WIRELESS CONNECTION
Make sure the latestwireless card driver is installed in the computer.Locate the wireless routerhigher and away from concrete and brick walls, foil-insulated walls. Locate the wireless routeraway from cordless phones and microwave ovens these can cause interference.You could be gettinginterference from other wireless access points or wireless routers in yourarea. Check the wireless broadcast channels in your area, and select one thatis unused or one that has the weakest signal strength.CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
Mar 15, 2012 | Computers & Internet
My hcl laptop with winxp shows very weak wireless signal strength at just 2 metre from the modem though other devices show complete signal strength. the device manager shows no problems with the hardware....
You can try this solution
  1. Right-click on the 'My Computer' icon on your computer and choose 'Properties'.
  2. Click on the 'Hardware' tab and then click on the 'Device Manager'.
  3. Now, find the 'Network Adapters' section and click on the little plus-sign to the left.
  4. Find your wireless network adapter and right-click on it and choose 'Properties'.
  5. This is where things will get different depending on the brand of your laptop and wireless card and which drivers you have installed. Browse through the different tabs and look for settings such as 'Power Management' or 'Transmit Power'. Adjust the settings to either disable the power management or increase the amount of power used by the network card.
  6. Now, test your wireless signal strength to see if you still have the same weak wireless signal you had before. The chances are that you will notice an increased wireless signal strength.
Jan 17, 2011 | Computers & Internet
I have the DIR-655. Poor coverage/Signal strength
What kind of construction surrounds your router? Weak signal indicates walls reducing signal strength. Try a repeater in weak areas.
Dec 30, 2017 | D-Link Xtreme N DIR-655 Wireless Router
Acer Aspire One D250 - Weak network signal strength with Broadcom 802.11g adaptor
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Dec 26, 2009 | Acer Aspire One PC Notebook
NetGear WNDR3400 N600 Wireless Dual Band Router (WNDR3400100NAS) Logo
75 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
