Question about Nintendo Wii Console
Wii wont come on.
My wii wont come on all of a sudden, when I turn the power button on it just wont work , nd its new.
    Scholar:
  • 104 Answers
Try disconnecting the power cord from the wall outlet and the wii and waiting 5 or 10 minutes, then reconnecting it...
Posted on Nov 29, 2009
    Sergeant:
  • 273 Answers
It might sound silly but is the power cable pushed all the way in? if so take your wii to game or similar and ask them to test with their cable on pretence of poss buying a new power lead if theirs works then new lead is what you need
Posted on May 20, 2009
MY drums were working fine last night, and have suddenly stopped working. The wireless connector is blinking fine, and i changed the batteries but they still wont turn on. Perhaps the batteries i changed...
Are the drums blinking? If so it is not the batteries, it could be not synchronised with your wii. If so press the orange buttons on both the wii and drum set.
Feb 18, 2011 | Nintendo Rock Band for Wii
Cant get pass the "press A button" screen
Turn off for a moment, try again, reconnect your controller.
Since its brand new, you can get it replaced if that doesn't work, dont waste your energy on it, just get another one, free replacement / warraty. Im sure.
Sep 05, 2008 | Nintendo Wii Console
Wii wont turn on
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that dosent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
May 20, 2010 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
Wii wires are hooked up but wont turn on
The power box on the power cord needs to be reset,,
unplug it from the wall and wii and retry,,
You may have to keep it unpluged over night
Feb 26, 2010 | Nintendo Wii Console
Wii will not power back up after sudden power loss any way to reset
This could be bad, also could be good.
1. Check your power outlet and make sure if you have a powersurge protector, that it hadnt tripped. If it is tripped, there is in most cases a button on the side of the powersurge protector for a reset.
2. In the case that this was not on a powersurge protector, try moving the Wii to another outlet and try it from there. If that doesnt work, buy a new power cable. If the new Cable doesnt work, the Wii is most likely Fried and will not be able to be operational again.
DrakeTech
Dec 24, 2009 | Nintendo Wii Console
Bought new wii remote and wont power up
The wii remote won't power up the Wii itself, or you can't get the wiimote to come on?
If it won't turn on the Wii, it may have to be synced with the system. Not really sure, though. But to sync it, take of the back of the wiimote(the battery cover) and open the little flap on the Wii. There should be red buttons in each. With both on(turn the wii on manually with the power button on the system), press both red buttons at the same time. Alternatively, you can go to the menu and sync wiimotes from there.
If the wiimote won't come on, make sure the batteries are new/charged.
Nov 26, 2009 | Nintendo Wii Console
Wii control
Try to reconnect your wii-motes, by using the red button on the wii underneath that front flap where you would put the SD card. and then the other red button on the controller where you put the batteries in. and make sure the batteries are fresh
Aug 16, 2008 | Nintendo Wii Console
Remote malfunction
Do the LEDs light up when you press the buttons on the Wii Remote? Try simply turning off the console, and pressing the power button a couple times firmly on the Wii Remote. If it turns on the Wii, the connection should be established. If it doesn't turn on the Wii, some hardware is defective. Recommend calling Nintendo Support if this happens.
Aug 14, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
325 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
