Question about Cabela's Smoke Canyon Light-Assist Charcoal Grill
Charcoal grate and hand crank
Following the instructions it does not seem clear how to attach the moveable charcoal grill to the hand crank and the brackets (Step 14) Any help would be great!
What kind of charcoal or lava rock do I buy for my indoor Char-glo waste king universal grill
You have a gas grill, so you don't want charcoal. You need lava rock, any big box hardware store carries them (or Amazon). Doesn't really matter what brand, just get a size of rock that won't fall through the grate. Take a piece of your old rock that won't fall through the grate with you to the hardware store. Get something as large or larger.
Jan 03, 2015 | Grilling
I'm trying to locate a replacement coal grate (perferably in stainless steel) . Can you supply one? Thanks tlynch@inficon.com
Sorry, we don't sell anything on FixYa. However, if you get the dimensions of the grate you needand search around on Google for some the Grill Parts & Accessories sites and you're more than likely to find what you need. I will caution you, Stainless Steel Grates are expensive. Plus, they do not do well with charcoal. The charcoal gets so hot against, that it will pop and pit. It's not like doing it on a gas grill, where the heat is moist and the stainless retains it's integrity. Unlike coal or charcoal, which is an extremely dry heat. You may be better off with Cast Iron. Once it's seasoned, it should do better than Stainless Steel.
Hope this helped you. Please let me know. Thanks/
Jun 21, 2011 | Patio Classic 2000 Series Grill
How do you condition a new grill?
Start some coals with the grate off the grill. As the coals are heating up, coat the grate in *vegetable* shortening using a paper towel. Place the grate back on the grill over the hot coals and cover. Allow the coals to burn off; this process will coat the grate with a protective layer of oil.
You might also consider running the grate through a burnoff process BEFORE curing to remove any coating the manufacturer used for protection during shipping. To do this, burn some coals for roughly 30 minutes under the grate with the lid down, let cool, then condition per previous instructions.
Jun 24, 2010 | Brinkmann Smoke 'n Grill Double-Grill...
I lost the charcoal grate and the cooking grate. Where can I buy replacements
Measure the inside of the grill and go to Lowes, Home Depot or any large hardware outlet. They all carry a variety of grill and grates.
May 19, 2010 | Patio Classic 4000 Series Grill
Cooking info
You can print a new manual off of www.chargriller.com. But, the basics are:
1) Take cooking grates off of grill
2) Put enough charcoal on the grill to cover the desired cooking area two coal layers high
3) Pile up desired amount of charcoal (laid out in step 2)
4) Spray lighter fluid all over charcoal pile
5) Light the pile
6) Let the pile burn until the flames die out and most of the coal has turned white
7) Spread the coals back out (use tongs they will be hot). Put any coals that are still black on top of the white ones.
8) Put your cooking grates back on the grill and let the last black coals turn white and the grates heat up.
9) Now cook!
Apr 14, 2010 | Char-Griller Super Pro
Where can i get a grate to hold the charcoal from. it goes over the ash pan
Go to your local big box builder's supply company and get something called "expanded metal". It is some grate sheets for various purposes. Expanded metal is a perfect use for a charcoal holder in a grill. Try it!
Nov 28, 2009 | New Braunfels Grilling
I need directions for using a weber grill
Open the bottom vent, open the top vent. Start your charcoal in a chimney starter (my favorite way). Dump in the burning charcoal. Wipe down grill grate with canola or other high temp oil. Place grate on grill, cover, set top and bottom vents to desired temp. Cook food. Cleanup.
Jun 14, 2009 | Grilling
Patio classic 6000 charcoal grill
I could not find a replacement but used 2, 18" weber circular grates, one on each end and they overlap in the middle. It is not and ideal arrangement but it allows me to continue to use this discontinued charcoal grill that I love so much
Aug 25, 2008 | Patio Classic 6000 Series Grill
Cabela's Smoke Canyon Light-Assist Charcoal Grill Logo
Top Cabela's Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Cabela's Grilling Expert? Answer questions, earn points and help others
