Optimum 260299 remote
Cannot find setup button
Hi there need a code for optimum universal remote for this model of tv
google the make ,model of tv see if there is a tech support for it
Mar 18, 2015 | Universal Televison & Video
Manual for tevion UR4200 remote
Many cable providers use the same equipment. It looks like that one looks like it is used by Cablevision/Optimum. Some information is available on their support site. Does this look like it will work?
Program your Optimum TV Remote Control
Jan 01, 2015 | Televison & Video
Need a code for my RCA dvd player, for my optimum 4in1 remote to control to work the RCA dvd player
If your Optimum remote is programmable, you can use its code search feature to find a suitable code. If a search through all codes stored in the remote fails to work, you may have to try another programmable remote.
Dec 11, 2014 | RCA Televison & Video
Require instruction to set up optimum 260299 remote control
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may
be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Nov 20, 2013 | Televison & Video
Home living 4 in 1 remote control cant get to work
1) Change by new batteries alkaline
2) Clean the contacts batteries with special spray contact very well.
3) Retight the springs contact batteries very well.
4) Resolder the wires contact batteries.
5) Put the code again, and try it. If doesnot work go to the repair shop
God bless you
May 11, 2012 | Televison & Video
Need code to use for the tivo remote
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
Mar 23, 2011 | Televison & Video
I need to get a code for optimum controller my t.V company is sharp
I didnt have enough information about your remote to make sure I got you the correct codes. It appears there are about 3 different remotes they use. The link below takes you to there site. Click on the remote that looks like yours and follow the instruction to get your code.. seemed pretty straight forward when I tried it.. Good luck..
http://optimum.custhelp.com/cgi-bin/optimum.cfg/php/enduser/std_adp.php?p_faqid=1420&
Oct 17, 2010 | Televison & Video
How do i delete subtitles from my tv with a optimum remote control?
its on the setting buttons on the left toward the top of the remote. within there you will find closed caption options
Aug 31, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
