Question about Frigidaire Washing Machines
Water won't drain after the wash cycle. when i go to the spin cycle to try and drain the water, the washer makes a humming noise.
  • 26 Answers
Either you have a clog in the discharge line or you need to replace the pump.
Posted on May 25, 2009
Won't spin
Hello fopdycke - Typically when a washer does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage pump or hose may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, timer, faulty pump or control board not communicating correctly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Crosley 5000 front load washer won't spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with either the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 24, 2012 | Crosley Washing Machines
When tub drains beeps twice and won't continue
Hi - Does the drain pump make a humming noise as well? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer won't drain or spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty pump, timer, or door lid (if it is a laundry center).
Oct 11, 2012 | Frigidaire Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer
relay switch between timing circuit and spin cycle is faulty
Apr 03, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
