Question about Dell Dimension E520 PC Desktop
Usb ports not recognizing devices
When i plug certain devices into my usb ports it doesnt recognize them. somethings is wrong with all of my usb ports
  • Dick
    Dick May 11, 2010
    If ALL of your USB ports are acting up there is a problem with your USB controller built into your motherboard. You can try going to the device manager and re-installing it after rebooting. I would perform a virus scan before I did that if I were you.
    Have they ever worked? What happened just before they quit? Have you tried restoring your system to a time when they did work?
    President:
  • Dell Master
  • 1,996 Answers
You might be drawing too much power from the usb port, if you're not using a powered usb hub.
Unplug all your usb devices. Go to the device manager and uninstall the usb controllers, then reboot your system and they will be reinstalled. connect the usb devices one by one and try to ascertain which is causing the problem. Some powered devices like printers can conflict with devices that require power from the port, and sometimes there are driver conflicts that can be resolved through the use of a hub, or connecting the devices to different ports or in a different sequence. You may also need to update or reinstall drivers for usb devices such as the PCI bridge. Please see this link for more info on troubleshooting usb. And this for possible cause.
For further reading, see here and here.
If you work through that and still have trouble, write back with the results and we'll help you to sort it out.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 19, 2009
  • 4 Answers
If they were working before, just reboot. If they never have, I would reccomend contacting whoever you bought the computer from and asking if it's under warranty.
Im running win7, and it does not recognize this device which is a usb hub 4 port
A lot of times it won't recognize these devices until you plug something into them. Have you tried plugging in a flash drive, printer, etc to see if it's recognizing it but not showing it?
Jul 19, 2011 | Eforcity 4Port Octopus USB 20 Hub Black
Tip
How to fix ?USB device not recognized? error in windows
Are you getting a “USB device not recognized” error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn’t work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn’t work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an “Unknown Device”. 42b721d.png
So how did I finally fix the problem? Well, apparently it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
on Jul 08, 2010 | Computers & Internet
Msg which i get :- one of the usb devices attached to this computer has malfunctioned and windows does not recognize it. try reconecting the device. if windows still does not recognize it, replace the...
In most cases this message is fairly true and accurate. Whatever it is that you plugged in is most likely broken. Two things you can try to test this: 1. Plug it into another USB port in your computer, if it is the same message, move to step 2. If it works, then there may be something wrong with that USB port on the computer. 2. Try the device on another computer. If you get the same message, the device is probably broken. If it works, then most likely there is something wrong with the USB ports on your computer. Let me know if you need more assistance.
Jul 01, 2011 | Computers & Internet
I have plugged it in and it my computer will not recognize that the USB is even plugged in, but it does charge the camera.
Try all the different USB Ports on your computer, sometimes certain ports can 'glitch' and not recognize the device that you've plugged in. If you've tried plugging it in all the ports and your computer still hasn't recognized the camera, re-install the driver software for the Olympus SP800UZ.
If all else fails, you can also contact Olympus customer service, they're quite prompt and helpful.
May 17, 2011 | Olympus SP800UZ Digital Camera
I have a Craig mp4 .. but I'm trying to use it but i do not how .. because when i connect it to the computer it is not recognized by the computer please help me
Hi, Are you getting a "USB device not recognized" error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
usb device not recognized
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn't work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn't work!
You may also see in Device Manager that the device shows up as an "Unknown Device".
unknown usb device
So how did I finally fix the problem? Well, apparently it's a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
Have a nice day...
Mar 02, 2011 | Audio Players & Recorders
Hello, I am having trouble with my usb ports. It does not recognize anything that I plug into the usb ports. I did a system restore and it still does not recognize the usb ports. It only recognizes it if I...
reinstall your usb controllers and handlers off the factory system disk that came with your system..something corrupted the files somewhere ...system restore wont replace deleted system files only restore user settings when you put the disk in it will have a section to restore drivers...select usb and reinstall then restart the system
Sep 28, 2009 | SimpleTech 500GB SimpleDrive Pro External...
My EasyCAP doesnt work!~
hi there,
if your usb port is not recognized by your computer anything you want to install in your usb will not function,try to check your usb on device maneger and updated your driver through website,
if your game controler is not recognized by your computer go to control panel click game controler and add your device follow the wisard instruction and install your controler,controler is plug and play device.have a nice day,regards
Jul 10, 2009 | DekCell (CPA-1040)
I have Toashiba laptop Satellite A135-S2276. The laptop doesn?t recognize my USB flash drive. Apparently the device was detected by Windows because as soon as I plugged it in, a balloon pooped up and it...
Check it on another computer. if it still doesnt work then your backup is gone. if it does work maybe you should take it in. also try other accessories in that same port. if other stuff doesnt work then you'll probably need to fix the port. also check the drive on any USB ports in the back of you pc.
Regards
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
When i plug in the jumpdrive on any computer it says USB device not recognized, please help
Well, it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
P.S. if it is a laptop, power up the laptop with just the batteries, not plugged in to fix this issue.
Give this a try and come back to tell us if it worked or not.
May 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Not recognized by PC
First off.. Make sure your software and drivers are up to date...
Second, try re-installing Windows Media Player or if you have WMP 10 installed, try upgrading to WMP 11.
Also, if you plug in something else to your USB port, does the PC recognize it? Or, if you try your GoGear on another computer, does it work ok?
Apr 06, 2008 | Philips GoGear HDD6330 MP3 Player
Dell Dimension E520 PC Desktop Logo
1,101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
